Results 1 to 11 of 11
Thread: Snake Oil - Can I get an opinion?
    Jan 2013
    Houston, TX
    1,079
    The local AM garden guy is pitching this stuff. http://www.crystalclearchems.com/
    Cupric Sulphate Pentahydrate, Zinc Sulphate Monohydrate
    Looks to me like an algaecide. I am planning to send him an email directing him to TFP and the hazards of blindly dumping chemistry in. Hopefully I can head some AM radio off at the pass.
    Chris
    Last edited by karmabiker; 06-02-2014 at 09:32 AM. Reason: fixed the comma locations fro the cut / paste.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Snake Oil - Can I get an opinion?
    Ugh. Metals. Copper. Unless green hair becomes hot in Milan, pass. Even then... pass.
    Isolated Spa - 345 Gallons
    Jan 2013
    Houston, TX
    1,079
    I'm wondering specifically what the purpose of the Zinc Sulphate Monohydrate is. I understand the copper (algae control, turning hair green and staining the pool).
    Best I can do is " Zinc sulfate, like many zinc compounds, can be used to control moss growth on roofs." from wikipedia.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by karmabiker View Post
    The local AM garden guy is pitching this stuff. I am planning to send him an email directing him to TFP and the hazards of blindly dumping chemistry in.
    Chris
    Unless TFP pays him I doubt he will care. The snake oil folks are paying him for his pitch. Most AM fix it type shows are really nothing more than an informercial. Generally the "host" pays for the air time and makes up for his costs through partners & sponsors.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Some people like camouflage stains on the walls....
    With the amount of rain you folks have been getting, I wonder if the stuff would ever build up enough to get to stain level?
    Snake oil is good if you have a squeaky snake.
    Support the site
    Jan 2013
    Houston, TX
    1,079
    Quote Originally Posted by JamesW View Post
    Chuckle. Good one.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Jealous, Richard?
    Jan 2013
    Houston, TX
    1,079
    My CH is loving it.
    Mar 2007
    San Rafael, CA USA
    12,082
    As described in this paper, both copper and zinc have algicidal properties against freshwater algae.
    Jan 2013
    Houston, TX
    1,079
    Wow. Not sure if it was my email or something else, all references to crystal clear have been removed from the GardenLine FB page and the KTRH page.
