Results 1 to 8 of 8
Thread: CYA new above ground pool
    calypso's Avatar
    May 2014
    Pittsboro, NC
    8
    We purchased an above ground pool from Craigslist and hired a professional to set it up with a new liner. He did a great job, but left us on our own once it was half full. It sat two days while we thought about the deck and then turned green. I went to the pool store and got a shock treatment and started looking for answers and thankfully found your site.
    I've been using the test strips for the past two weeks while I waited for the real test kit. I have been adding chlorine and muriatic acid daily based on the test strip results (I know they aren't as accurate) that were consistently FC 0, pH 8.5, TA 200
    I finally got my Taylor k-2006 kit this weekend and did my first real test:
    Free Chlorine - never got it to turn pink; I know I have CYA issues so didn't bother wasting indicators
    pH - 8.0 (or higher?)
    TA - 180 (am I looking for true blue or is purple ok?)
    CH - 190
    CYA - I mixed then filled it to the top but never could see the black dot disappear - -30?
    I bought Cyanuric acid and am ready to put it in a sock and get it in the skimmer. My question is how much CYA?
    Poolmath tells me I should add 6 lbs of dry stabilizer, but I've read not to over due it. What should I start with this week?
    We filled the pool with well water and it looks great since the shock. If it weren't for the test strips I would think everything is great. Will the pH issues be resolved with CYA too?
    Thanks!
    11,000 gallon (16'x27'x54") Above Ground, Sand Dollar Top Mount Filter, Baquapure 2200 2 speed Pump 60 gallons/minute, bought used on craigslist & had a professional setup and install with new liner in 5/2014
    30,395
    Re: CYA new above ground pool
    read "The ABC's of Pool Water Chemistry" up in Pool School. That will answer a lot of your questions. You should be shooting for a CYA of about 40-50 ppm. PoolMath will tell you how much that is.
    Oct 2013
    Chapin, SC
    1,141
    6 lbs is just right. But I'd do it in steps 4 lbs to start, do a test after a week and add the remainder to get you to 50. that will also drop your pH by .81 initially and .91 at the end. You must have bought cal hypo shock to not have any cya.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    calypso's Avatar
    May 2014
    Pittsboro, NC
    8
    Thanks! It was cal hypo - and I was so happy to have such a helpful pool guy, especially when he said I could bring in my water and he'd test it for free. Glad I found you guys first! I've read all the pool school pages, but am still watching youtube videos for practical application. The one sock holds about 2 lbs. I don't think I can fit another in the skimmer - is there another way? Should I keep adding muriatic and bleach as the poolmath calculator tells me or give the cya a chance to do its work?
    Oct 2013
    Chapin, SC
    1,141
    How many return jets do you have? I have two and put 2 lbs in each of the 2 socks I use. Here's a link to show you my setup.
    https://www.dropbox.com/s/ndmcbhx7vm...2011.52.39.jpg
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Soccer socks are the best! Nice and long, usually 2 layers of fabric for durability, less chance of holes. Bonus points for pink ones. I can get 4 lbs in each if I really need to.
    Isolated Spa - 345 Gallons
    calypso's Avatar
    May 2014
    Pittsboro, NC
    8
    Just one return jet. I watched a youtube video that put the cya into the skimmer basket - I didn't know I should put it in front of the return jet. Thanks for the pics - I'll get four pounds in now. Love the pink!
    Oct 2013
    Chapin, SC
    1,141
    Now, THAT'S a sock!!!!! Calypso, squeeze them now and then to speed the dissolve process.
