Results 1 to 7 of 7
Thread: Confused about the Liquidator
    May 2014
    Oakville, ON
    2
    I just went through a very frustrating experience getting my pool water balanced. I learned more about pool water chemistry than I ever thought I would want to know. The water is now balanced and I want to keep it that way so I'm looking at going to a liquid chlorine dispenser like The Liquidator. First some basic information:
    16 x 32 IG vinyl liner
    Sand filter
    Hayward chlorinator
    Ozone generating system
    Oakville, ON (Near Toronto)
    I have read the numerous posts on this site and the information from the company on the Hasa Liquidator. I also watch a Youtube video that a guy from PA posted on how to install The Liquidator.
    The manual from Hasa says to connect the feeder line (in) just before the pump which basically uses the pump's suction to pull the CL out of the tank and into the pump and then to the pool.
    The video connected the feeder line to his old chlorinator feeder line. He capped off the other end that fed water to his chlorinator. He then connected the fill line to The Liquidator to the drain plug on his pump. I am assuming that this would have the effect of the pump pushing the water into The Liquidator and then back into the return line.
    I have a few more questions:
    With the connections as recommended by the manufacturer the CL is being added before the pump and filter. I was always told that was bad, that you always want to add chemicals directly in the pool, or in the case of the Chlorinator, it gets added to the return line just before it leaves my shed. I read one post that suggested that because the CL being added by The Liquidator is diluted, that this is not a problem, but it was unclear as to what concentration of bleach or liquid CL they were using. Does it matter?
    To my last point, what concentration of bleach or CL is recommended.
    I hope I have not posted questions that have been asked numerous times before. I did try to read as many as I could before posting.
    Thanks
    Joe
    16 x 32 In-ground Vinyl liner
    80,000 litres (21,000 US gallons)
    Ozone gas system
    Chlorinator using 3" pucks
    Re: Confused about the Liquidator
    Whatever concentration of bleach you can get at a good price is fine.
    There is no risk to the plumbing from injecting before the pump because the chlorine has already been diluted by the Liquidator and again at the point of injection.
    By the by, we don't recommend using ozone with a residential pool.
    May 2014
    Oakville, ON
    2
    Thanks for the quick response.
    WRT Ozone. Can I ask why? They are quite common here in Ontario.
    Ozone gas system
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Welcome to TFP.
    There are several posts on it. Here are a couple that discuss it:
    http://www.troublefreepool.com/threa...l=1#post558491
    http://www.troublefreepool.com/threa...oking-up-ozone
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Another way to go instead of the liquidator is a Stenner Peristaltic pump... Quite a few pool owners have them on here, myself included... I couldn't buy a liquidator where I live and postage costs to Australia made it too expensive, so I went with a Stenner pump and tank...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    JoseJones
    Guest
    I just tapped into the drain on the pump basket when I installed mine. Never have had an issue since. The CL settles to the bottom of the Liquidator so you're pulling out already diluted CL into the pump, and the volume of water in comparison to CL is HUGE. No need to worry like @JasonLion mentions.
    Don't let these peristaltic pump guys steer you wrong. The pumps are $$$, take a lot to setup correctly and when the parts on your Liquidator wear out you call HASA and they will replace them free of charge for the lifetime of the tank (tank isn't covered). I know the Liquidator isn't the latest gizmo, but it's probably one of best pool products for the money out there a pool owner can buy to make their life easier.
    Quote Originally Posted by JoseJones View Post
    I fought with the liquidator for weeks and finally went with the Stenner. I was tired of air leaks, white ****, floats sticking, adjusting flow meter balls, needle valves, etc
    Stenner hard to set up? Not really. I had to drill two holes for the Liquidator...and only used one of those with the Stenner. I bought the Stenner pump tank combo so all I had to do was hook that up to the pool return line.
    The hardest part was setting up the timer...which took about 15 minutes...and that was only because I wanted it to come on multiple times during the day instead of just one or two.
    The only thing I do now is open the lid, and add bottles of bleach. No checking the floats in the liquidator...or adjusting the flow meter...or losing pump prime because of air leaks.
    More expensive...yes...but well worth it from my point of view.
    17K Plaster Kidney (17' x 37') w/ Spa
    Jandy DE filter, Jandy JHP 2.0 pump, Polaris 280 cleaner, Stenner set up with bleach
    Jandy LJ Heater and Aqualink RS controls
