Results 1 to 7 of 7
Thread: What needs to be level? Post only or the middle too?
    Jun 2014
    Harker Heights
    7
    I can't find this answer anywhere in the forum. I've got a 18x33 Vogue pool I'm sinking about 27 inches in the ground. If I have all the post on paver's leveled within a 1/2 inch, does the interior ground need to be level? I've good, hard caliche dirt (clay dirt) for a base that has a little "wave" to it. The wave isn't more than an inch at any one spot. I'm going to place 1/2 foam for a base then the liner. Am I good or should I bring in a load of sand to level those low spots through the middle.
    Thanks
    Re: What needs to be level? Post only or the middle too?
    The perimeter where the post and bottom rail rest is what needs to be level. Sounds like that's what you've done. The rest of the interior floor can be as wavy or flat as you want. Some people put deep ends in their above ground pools. You just have to decide if if bothers you know because if it does it will continue to bother you until you change the liner.
    May 2012
    Montville NJ
    545
    Just don't get too crazy. A bit of a wave or dish in the bottom is fine however it may annoy you to no end when you use the pool (if you are like me), but if you want to dig a "deep end" you need to get an expandable liner. If you try to do it with a normal liner, bad things will happen.
    Thanks
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jun 2013
    Newcastle, Oklahoma
    508
    OP - On our pool the builder leveled the posts seperately, then went into the pool and dug out the center deep area and formed the bottom. as said, it can be however you want it.
    +1 on the expandable liner AGP. mine just got completed saturday. PB says we have to wait a week before we can swim... .....so that we wont leave foot impressions in the bottom. Man, I cant wait to jump into that 7 ft deep end!!!
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Jun 2014
    Harker Heights
    7
    Thanks for the response, sounds like I'm good to go. I can live with small wave for what it is....an AGP buried! lol. Can't wait to get in....
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Quote Originally Posted by Falzy View Post
    Personally, I would try to level the waves with sand. I think you'll be surprised how annoying those little waves will be once you have it filled and after all the hard work you put in burying it.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    Casey's Avatar
    SW PA
    10,423
    Those waves have sweeping the pool a BEAR! I would reconsider having a wavy, bumpy, floor!
