Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Pool finally going up
    Jun 2013
    west fargo
    72
    So after weeks of trying to level the pool. It is started. Did have a hole in the liner. So here is the start. Hope she stays level. This is the low side of the yard.
    This is the high side of the yard
    Middle side a I will. Call it
    Middle side b
    It seems to be staying pretty level so far. ....
    20'x54" intex ultra Sand filter. with SWG Still work in progress will have Resin 24" fence around the top. Hooked to a 10x6 Deck that is attached to another 10'x6' Kids Club house. Slide from main deck into pool. Intex softwall lights. Kenwood Marine radio sealed in a deck box all Bluetooth controlled with Pyle 5" outdoor speakers.
    Mar 2013
    New York
    85
    Re: Pool finally going up
    Good luck . I know it's not much fun getting there but we'll worth it in the end !
    Jun 2013
    west fargo
    72
    Thanks
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    If it is level so far, it will probably stay that way. Don't forget to level all of your legs in and out and side to side. I want to say I could still slide mine around on my pavers until I had about 3 feet of water in it. Up until that point the water hadn't fully expanded the liner so it wasn't putting much pressure on the legs. The liner isn't perfectly up and down. It gets slightly wider toward the bottom of the pool. Once it gets so high, it starts pulling downward tightening against the frame and putting pressure on the legs.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    Casey's Avatar
    SW PA
    10,421
    Looks good! Keep us updated on your fill and finishing pics!
    Jun 2013
    west fargo
    72
    So the pool is full here it is getting closer I will post a full pool pic tomorrow., It is maybe a 1/2" off level. I did notice a couple of small wrinkles on the bottom which stinks but the legs all stayed on the pavers.
    Here It is almost full. You can see how close I am the water level made it almost perfect. I am very proud of this. I will be adding more pictures through out the week. I am going to be working on the deck build next.
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    From what I can see your pool is looking good! Nice job!
    Jun 2013
    west fargo
    72
    So here is part of the deck.
    Jun 2013
    west fargo
    72
    Ok zo I want to add something else I previously. 2 yrs ago had a small intex pool. With thise cheap hang over the wall skimmers. I put that on with the old 1000 gph pump with filter a seems to be working. Here is a picture.
    The return just flows back in right now.
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Quote Originally Posted by Havlc2u View Post
    The wrinkles are a bit annoying, but on a positive note, dirt will gather against them and make it easier to vacuum.
    Jun 2013
    west fargo
    72
    Ya mac the temp of the pool with just a little water was only 52degrees so I wasnt able to feel my feet seems they formed after I filled for some reason
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Yep. I know your pain. I think ours was 64 F when we were smoothing wrinkles. I wish we could have let it sun for a good part of the afternoon, but the wind was starting to pick up so we had to get some water in it so it wouldn't fly away.
    Jun 2013
    west fargo
    72
    Same here we had a thunderstorm coming in. Its not to bad i think it will survive
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Sent from my SM-G900P using Tapatalk
    I think so too. If I ever have to drain for what ever reason, I'll work on them at that point. Until then, I will save myself time vacuuming.
    Jun 2013
    west fargo
    72
    So we have progress. I am very excited about the progress.
    Here is from the house.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Looks fantastic... Kids are going to love it... Have you tested the water yet?
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2013
    west fargo
    72
    Yes I used shock on it yesterday. It seemed to be in line. I did have to add Algecide. We get the boatman and backswimmers. Hope that solves it.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    You need to read pool school and get rid of the algaecide and shock... Do you have a Taylor or TF100 test kit????
    Jun 2013
    west fargo
    72
    I ordered a Taylor today
  20. Back To Top    #20
    Jun 2013
    west fargo
    72
    Update with some pictures. From around the pool.
    2
