Thread: Solar blanket
    donniespool's Avatar
    Nov 2013
    Tucson
    31
    Solar blanket
    I have always used solar blankets. Usually they last a year and a half then begin to disintegrate. My last blanket was recently disposed off during my recent green pool battle. It was falling apart also. I have a home made roller that works well. Is there another method I have overlooked. It seems like I read that cutting the otherwise unmanageable cover into pieces was a decent idea and worked. Also, now that I am onboard with the TFP method is there a problem using the solar blanket..As most know, they heat the pool 10 degrees without a problem..in a fairly short amount of time..thanks
    in ground gunite/plaster 16x30..3-6-3 play pool, sand filter, 1 hp pump..single speed... built in 77 replastered in 05
    15300 gallons. chlorine tabs no longer...tf-100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Solar blanket
    Your solar cover won't affect the TFP methods at all if that's what your wondering. I use one and you can probably guess I follow the TFP methods.
    I have mine cut in half and that helped out a lot with managing it. I also use the solar saddle's to store it. They work good for me. 😎
    Jeff
