Thread: Suction Side Leak
    weatherillgrp's Avatar
    May 2014
    Cortez, CO
    26
    Suction Side Leak
    I have a suction side leak. Bubbles in returns. Seems to be getting worse. I have checked the pump basket lid, the drain valves in the pump. O rings clean and lubed. Checked bottom drain and skimmer valves. Also all PVC connections above ground on suction side. Used the slow hose/water method. I did not see anything change in the pump basket when I used the water method. Prior to digging does anyone have any other suggestions or techniques for checking above ground?
    18K gal, IG vinyl, 1 hp single phase Pentair Pinnacle pump part 7-177474-01, Star-Rite Cristal Flow Filter model T-240BP-1, 266,000 BTU Raypac gas heater model PR266AENC, Coverstar electric safety cover, Hayward Navigator Pool Vac, Pentair model 300 Auto Chlorine Feeder( not using). TF-100 Test Kit. Built June 2007
    Re: Suction Side Leak
    Check out the article about this in the Solving Problems section of Pool School.
    Mar 2013
    CT
    353
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
