Page 1 of 3 123 LastLast
Results 1 to 20 of 59
Thread: Looking for advice to clear Cloudy Water
    Jun 2014
    Minneapolis
    27
    We bought a home, which was in foreclosure, a couple of months ago which came with a pool. The pool was winterized for the last two years(at least) and we had it open 6 weeks ago.
    Following are some of things we have done so far
    Pool people put the new filters and opened the pool. We Shocked the pool with liquid Chlorine (13% ) about 16 Gallons (8, 4, 4 ) in total and took out lot of debris with Pool Leaf rake and manually vacuumed it and got the PH under control however the pool was cloudy. Shocked it with Lithium Shock and then sprayed with Revive to get all the Organic particles to settle and vacuumed it again. Clean the Cartilages 3-4 times in the last six week. We got another water test done last week and the Total dissolved solids were 2100 and were asked to drain 25% of the Pool. We did that and got the water tested again. Following are today result with Water still cloudy. ( we have been running the Pump 24/7 )
    Free Chlorine .1
    PH 7.5
    Total Alkalinity 179
    Calcium Hardness 171
    Stabilizer 15
    Copper .2
    Iron .0
    Total Dissolved Solids 1200
    Just added Proteam Metal magic to reduce the copper. Idea is to balance the Copper first, then Adjust PH and Alkalanity, then add more chlorine. We have talked to few pool stores over the last six weeks and got different range of recommendations and not sure which one to follow. I have been reading TFP forum from last couple of days and I am hoping I will get some expert opinions from the knowledgeable people here to see if we are on the right track
    Thanks
    17K gal , vinyl, .75 HP Hayward Tri Star Pump,Hayward C4025 Filter, Unicel cartridges,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Looking for advice to clear Cloudy Water
    I feel like a broken record but...
    The key is to get your own accurate test results and then take care of only what needs taking care of. Order a proper test kit - I suggest the TF100 since that's what I use - and post up results and we can walk you through it. You can be done with the pool stores -- except for obscure pieces of hardware -- for good and have sparkling clear water from here on out.
    What you're describing sounds like the pool store people are just spinning the Wheel of Fortune at your expense.
    Jun 2014
    Minneapolis
    27
    Just ordered the Kit. Do I need to do anything in the meanwhile? should I have the Pump running or turn them off
    Richard320's Avatar
    Jan 2010
    18,967
    The one thing in your pool chemistry you can be certain of is that the pool will need chlorine. If it's cloudy now, it will be green again before you can test otherwise. I would suggest you add 5 FC every day, which works out awfully close to one 121 oz jug of 8.25% clorox. Don't expect it to do anything but keep it stalled there. And yes, run the filter. Maybe some of the cloudiness will filter out.
    Jun 2014
    Minneapolis
    27
    Still waiting for the Kit. In the meanwhile I have another question. It rained a lot over the weekend in Minneapolis like 4+ Inches and I got water behind my liner which caused it to bubble. The water is receding now and bubbles are going away ( there are still some wrinkles ) at the same time pool water have also gone down like 2-3 inches. Is this normal or I might have a leak now in the pool?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Ugh that is a little weird.
    Not normal...
    Jun 2014
    Minneapolis
    27
    I guess I might have a leak then, the liner is 7 years old and pool was not open in last couple of years.
    Also is it a normal practice not to have a Vacume pump behind your liner for these situations
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    What Richard said: What you're describing sounds like the pool store people are just spinning the Wheel of Fortune at your expense.
    This was a reply to someone else but I'm thinking you could benefit from it too.
    No way around it, you need to do some reading. Start here in pool school : http://www.troublefreepool.com/conte...etting-started
    They don't say "shock" here, it's SLAM. Here is the how to: http://www.troublefreepool.com/conte...tain-shockingl
    When you go to SLAM your pool you'll want to know the CYA level and use this table to figure out what level of FC you need to maintain. http://www.troublefreepool.com/conte...art-slam-shock
    If you start to follow the TFPC recommendations here you will not be needing or using the tablets (guessing you are talking about the 3" chlorinating tabs). http://www.troublefreepool.com/threa...-for-Beginners
    Her is a link to the calculator to figure out how much of what to add to your pool to get it blue and keep it sparkling. http://www.troublefreepool.com/calc.html
    Link to the recommended (and less expensive) chemicals to use instead of the $$$ pool store stuff: http://www.troublefreepool.com/conte...pool-chemicals
    If the pool is maintained you shouldn't need to shock. What you do is:
    Daily
    Look at the water, notice the clarity and color.
    Test the chlorine level and adjust if needed.
    Test the pH and adjust if needed.
    Examine the skimmer(s) and clean if needed.
    Use a leaf rake to remove any surface debris.
    That should get you started. From here on out, when in doubt ASK !!
    Solar Blanket, Well Water, Borax Added. 68
    Jun 2014
    Minneapolis
    27
    I just wanted to update our pool liner issue. Our liner actually went back to normal over the past few days. I guess there was no leak after all because we have not lost anymore water. It was some sort of weird illusion I suppose that the bubbles were so big that it pushed some on the water in the pool up, then once the bubbles started going away then water level came down but has stayed level.
    Anyways. we just started testing at home now and got our kit
    Here are the numbers:
    .5 FC
    1.5 CC
    CH 150 ppm
    Alkalinity 300
    PH 7.5
    CYA im still trying to figure this test out I think it was 30? but last week we had pool store test our total dissolved solids and it was 1200. We have recently drained pool 25% and refilled with fresh water.
    What should we adjust first? pool look more blue but still cloudy. What should we do first?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    TDS itself is a meaningless number that pool stores somehow still believe is relevant in any way. TDS is anything that's dissolved in your pool. Calcium, salt, cyanuric acid, borates, whatever's left of a beer that your rowdy neighbor spilled in there yesterday. You get the point. Lump all that together in one number and it tells you nothing about the chemical balance of your pool. In a salt water pool, there's over 3000 TDS because there's more salt in there to keep the SWG running properly. Should all people with SWG lower their TDS? No, it's necessary. TDS is a test remnant from when testing for CYA was unavailable (from what I recall...).
    It's the individual components of TDS that you test for individually that give you useful information about how to balance your pool.
    If you look at this list of relevant chemicals and levels, TDS is not there, because it tells no relevant story about your pool. ABCs of Pool Water Chemistry
    CYA can be a tricky test but you can dump the sample back into the squeeze bottle and retest several times. It's good practice and and average of your results gives you more confidence in the number.
    Read more on the SLAM - Shock Level and Maintain and read as much of the rest of all the stuff in the Pool School link up top and let it sink in. Then read some more. It's a lot to absorb but it's all great information. Asking questions on what you learn will get great answers from the excellent experts here.
    Isolated Spa - 345 Gallons
    Casey's Avatar
    SW PA
    10,423
    You need to SLAM the pool!!! SLAMing Your Pool
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Time to SLAM the pool.
    Might help if you can post a picture of the pool/water so we can "see" what it is you're looking at.
    Jun 2014
    Minneapolis
    27
    I started Slamming last night and got the FC to 8 this morning, added more chlorine in the morning to bring it to 12 according to the Shock Level per CYA 30.
    I am adding some pictures to give a sense of what we dealing with. In the morning the clarity was little better, I Vacuumed it which reduced it a little bit.
    Other issue we are facing is the Filter pressure has increased to 25 from last few days. before our water drain that it was 18 consistently. The pump might run with some air since water went down below skimmers. Our Cartridges are only 7 weeks old ( adding pics ) and I have cleaned them three times this week to rule them out without any results. Not sure should I wash them with Muriatic Acid. Any other ideas?
    Richard320's Avatar
    Jan 2010
    18,967
    The pressure is rising because the filters are getting clogged with the stuff you're killing. It's normal and expected and desirable. That means things are dying off and the filter is working! Time to clean them again.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    +1 What he said.
    Rotated your photo, sorry it's my OCD if you want to replace yours with this.
    Jun 2014
    Minneapolis
    27
    I cleaned them again and its still 25. But FC dropped to 1.5 instead of going up after I added the Chlorine in the morning. I tested twice to rule out the Testing error and both time it came around 1.5. Is this Normal?
    Should I keep Going with Slamming?
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by dizzle View Post
    If your CYA level is low, you will lose a lot of chlorine really fast to the sun. Did you ever get a reading on that?
    Jun 2014
    Minneapolis
    27
    Yeh I think it is 30
    Richard320's Avatar
    Jan 2010
    18,967
    Sounds normal then. You lost 4 overnight without sun, and about 10 with the sun over 6 or 8 hours. Keep slamming.
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,423
    Keep SLAM'ing and brushing.
