Results 1 to 7 of 7
Thread: Need Help
    Need Help
    I have had Baquacil in my pool for the last 2 seasons. This year I have developed the apparently common slime... I have no idea where to start and the pool stores around my area are Oh so Helpful *sarcasm*However, I am in the middle of the season and my kids would appreciate the fastest conversion. Can anyone tell me if it is easier to convert with a full pool or should I drain it and start. I have a small pool (15'x4') so re-filling is pretty inexpensive. I have begun reading through your posts and have found all your input to be very helpful!
    Thanks!
    Jodi
    30,415
    Re: Need Help
    Refill it.
    Drain all the water, change the filter media, and start fresh.
    You'll still use a bunch of Clorox on startup but it will be pretty fast.
    NCFlyersFan's Avatar
    May 2008
    NE North Carolina
    116
    Re: Need Help
    Hi Jodi and welcome to TFP!
    While all pools are different, you can count on at least a week to do a conversion. The two biggest factors that influence the time required are the initial Baq levels and the diligence with which you add and maintain the chlorine at 15 ppm. Something else to consider is the efficiency of your filter. It sounds like you have an Intex pool. If that is the case, it will take a while to clear the water once the Baq is consumed by the chlorine if you choose to do the conversion.
    If you want to just drain and refill, make sure you replace the filter media before you refill the pool to minimize the amount of Baq the chlorine will have to consume.
    In any case, good luck and don't be afraid to ask for help.
    13,000 gal AGP, Hayward X-Stream 100 sq ft cartridge, 1 HP Hayward Power-Flo Matrix Pump, all on two 6-hour on cycles per day. Baquacil to BBB convert.
    "It is necessary for us to learn from others' mistakes. You will not live long enough to make them all yourself." - Hyman G. Rickover
    Re: Need Help
    Thanks for the input! I have decided to drain, clean, and refill. Then start with the conversion... Where can i find information regarding conversion with fresh water?? Should I change my sand before I begin refilling?? Any suggestions on where to start! I am a beginner with pool/chemicals in general...
    Thanks!!
    30,415
    Re: Need Help
    Change the sand before you refill....that'll get rid of more of the baquagoo.
    Several articles in Pool School will help you. Start with the elementary ones at the to[p and procede down to the conversion articles.
    May 2008
    NE North Carolina
    116
    Re: Need Help
    Draining and refilling AND replacing the sand before you refill will rid your system of the majority of the Baquacil. It will then just be a matter of adding chlorine and maintaining shock chlorine levels (15 PPM Free Chlorine - FC) to "consume" the Baquacil residue (until you have less than 0.5 Combined Chlorine - CC). I can't overstress the need to follow Duraleigh's recommendation to read the articles at the pool school. Here is the link: http://www.troublefreepool.com/category/pool-school/. Once you read a little, feel free to ask any questions you may have.
    You also need to get a GOOD test kit. The TF-100 in Duraleigh' signature line comes highly recommended. The Taylor K-2006 is also good.
    Re: Need Help
    Quote Originally Posted by jodi_45
    Thanks!!
    If you drain, clean and refill, there is no conversion!!
    Drain, clean, change your sand (and clean the filter) and refill... that's it! Then you can start balancing the water according to this article: category/pool-school/balance_your_pool_water.
    Happy swimming!!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
