Results 1 to 7 of 7
Thread: Not Too Pool Smart But Question On Pressure
    Jun 2014
    Syracuse
    3
    I just opened my pool and I had to replace the Lateral assembly in my sand filter. In years past, my pressure has only been 11 to 13 lbs. Now since starting up, my pressure is 17.. I have backwashed and rinsed several times. New sand and new assembly.. Should I be worried it is that high? No leaks in any connections either.. Appreciate any help!!
    30,431
    Re: Not Too Pool Smart But Question On Pressure
    Did you put in more sand than you had previously?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Welcome!
    Did you see 11-13 this year, or did you do repairs before the first startup? Pressure gauges die frequently, especially if they freeze. Does the needle go back to zero when you shut the pump off?
    Jun 2014
    Syracuse
    3
    I don't believe so but maybe a little..
    Welcome!
    I did repairs before the startup.. Pipe broke off of lateral assembly so I couldn't start it until replacing it.. The needle does go back to 0..
    Jun 2014
    Syracuse
    3
    Richard320's Avatar
    Jan 2010
    19,056
    Probably just a bad gauge. They're standard pipe threads if you want to replace it.
    30,431
    If you changed the plumbing and possibly added more sand, then your psi may have changed that much.
    I would just use the new psi as a baseline and go from there.
