Thread: 2nd year with Salt Water Filteration System
    Jun 2014
    Lisbon, IOwa
    2
    This is our 2nd year with the Salt Water Filteration System.... Looking for some pointer for
    this year. I was told to use Borax and another type of acid. I am not even really sure how many bags of salt to use to own pool up. Last year we experienced an algae problem and couldn't get our levels correct.
    Here is what we are looking at:
    10,000 gallon
    Above Ground Intex Pool
    22ft x 52 in
    110 - 120 v pump
    2500 gallon per hour flow rate
    1900 gallon per hour system flow
    Any help would be appreciated!
    Thanks
    Sara Jones
    Sara Jones
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: 2nd year with Salt Water Filteration System
    Welcome Sara - have you read any of the articles in Pool School?
    Mar 2014
    Las Vegas
    288
    Until you get a good test kit (TF-100 with Speed Stir (nice option)) I wouldn't put anything in the pool except bleach. Get the kit, run a complete set of tests and post your results. You will get plenty of good advice here.
    Last edited by jmbradwell; 06-02-2014 at 07:45 PM. Reason: computer doesn't type what i'm thinking.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Jun 2014
    Lisbon, IOwa
    2
    Pool is up and and salt is added for the amount of gallons we have. Tonight a friend is coming by with his testing kit to test it and help me out...hopefully we can do this right and get it stabilized as to where it needs to be.
    Sara Jones
