Thread: Newbie Pool Install Questions
    Jun 2014
    Katy TX
    11
    Hi all, 1st post,
    I just ordered a Saltwater 8000 15 foot pool with the following: Hayward 1HP 2 speed cartridge filter, Hayward Aquatrol SWG. Plans are to install the pool with perlite backfill, foam base, pool cove, and liner pad under the 25 mil liner.
    Being a newbie I know nothing about pool plumbing, but would like to install the pool equipment about 40 feet away from the pool. Is this a bad idea?
    If installed this way should I oversize the pipe and fittings to allow for pressure drop?
    I searched and cannot find plumbing diagrams showing recommended valves, etc. If someone could point me to one it would be much appreciated.
    BTW I also plan to order one of the recommended test kits and follow the recommended methods for startup and maintainance.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Newbie Pool Install Questions
    Welcome to TFP!
    You are ahead of many new people here, with the plans you have.
    For your distance, 2" pipe runs would be a good idea, however not absolutely necessary.
    Each pool is different so would be difficult to advise on what you will need for yours. I assume a round pool?
    Off the top of my head, one skimmer, and two returns. Each should have their own valves.
    You should also put unions on both sides of the pump (suction and pressure sides) and a valve and union at the outlet of the filter.
    Jun 2014
    Katy TX
    11
    Yep it's round. I think it comes with one skimmer and one return.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Are you installing the pool yourself or is installation included with the pool?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Since you will probably be running your pump on low speed except when vacuuming, I think 1.5 inch pipe would be fine, but you may want to go ahead and install 2 inch if you think you might ever switch to a larger pool. For the installation I would suggest watching a number of youtube pool installation videos, there is a lot of good information out there, as well as seeing how not to do it.
    Ike
