Results 1 to 8 of 8
Thread: Helpful Tips
    Fort Worth, TX
    83
    Helpful Tips
    I've been doing BBB for about 10 months and am certainly no expert.
    I have found a few things that make everything much easier.
    I'd like to share them.
    1. 2' of 1/2" PVC - Costs about $2.00. It lets you take your water samples 18" deep without getting on your knees and dipping your arm in the water. (I was told about this on this forum. I don't remember who told me but I thank them)
    2. Child's oral syringe - They cost a little over $1.00 at any pharmacy. They let you hit the right water measurement marks instantly, without retries.
    They look like this http://sciencebasedpharmacy.wordpres...dosing-errors/
    Get the 10 ml size.
    3. R-7065 CYA Standard Solution . I think you're wasting your time doing the CYA test without this. It's a standardized 50 ppm solution. You can use it to determine the proper lighting and distance from your eyes to hold the test vial. I was 30 ppm off on my CYA measurements until I got a bottle of this. The day I tested my water I found I needed to hold the vial about 4" under my chin rather than at waist level. It all depends on your vision and the lighting and it varies between people and circumstances.
    http://tftestkits.net/R-7065-CYA-Sta...ution-p34.html
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Helpful Tips
    Thanks for the tips ! Good job. 😎
    Jeff
    pakrh8r's Avatar
    May 2013
    Chicago, Illinois
    43
    Re: Helpful Tips
    How do you collect the water with the PVC as opposed to an upside down plastic bottle?
    5500 gal. Plastimayd & Vynall AG (12' x 18' oval), Hayward Swimpro Voyager Cartridge filter & pump, Hayward H150 heater
    TF 100 Test Kit, converted to BBB in 2013
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Re: Helpful Tips
    Quote Originally Posted by pakrh8r View Post
    Rinse the pipe, cap the end with your thumb, stick it in the water, uncap it and let it fill, cap it again and lift it out and let it run into your bottle. Saves sticking your arm in up to the elbow. Especially in winter when the water is cold.
    Oct 2013
    Chapin, SC
    1,141
    Re: Helpful Tips
    i'm 6'3" and too old to bend over that far
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Richard320's Avatar
    Jan 2010
    19,002
    Re: Helpful Tips
    Quote Originally Posted by timerguy View Post
    i'm 6'3" and too old to bend over that farr
    I use a 4' PVC pipe. myself.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Re: Helpful Tips
    Thanks, BillB and thanks Richard, I was wondering how that all would work. Now I can save my knees
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    pakrh8r's Avatar
    May 2013
    Chicago, Illinois
    43
    Re: Helpful Tips
    Very clever. I'll have to try that. Thanks.
