Thread: Fas-dpd testing
    Apr 2014
    Lumberton,nc
    20
    Fas-dpd testing
    OK guys easy on me here I'm woman lol so little bit clueless. I just tested water using Taylor k-2006 fas DPD kit. I used the 10 ml sample water because my little dipper said 0.05 on it so I assumed this was correct thing to do. After testing and multiplying drops x 0.5 I came up with 8.5 ppm for fc and 0.5 for cc. Are these numbers good lol?
    23k,IG vinyl,vs Hayward pump,sand filter,SWG, built 4/14
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Fas-dpd testing
    Quote Originally Posted by arieyellow View Post
    "Good" is a relative term.
    Your FC level is dependent on your CYA level. If CYA is below 100, then, yes, you're good. http://www.troublefreepool.com/conte...art-slam-shock
    It's a bit high for a pool with no CYA, but still low enough for swimming in.
    Apr 2014
    Lumberton,nc
    20
    Re: Fas-dpd testing
    My cya level was 40 if that helps
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Fas-dpd testing
    If you check that FC/CYA chart you'll see you're a little high on FC, which is wasteful. But you're still below shock level.
    You never want FC below 3 with 40 CYA, and when you dose, aim for 5. When you recheck it the next day, if you're below 3, then target 6 the next day. If you're losing more than 4 in 24 hours without a bunch of kids or drunk adults to blame for it, then you have a problem.
    Apr 2014
    Lumberton,nc
    20
    Re: Fas-dpd testing
    OK thanks very much I appreciate it!!
