Thread: Water filter pump
    Jun 2014
    SWEDEN
    3
    Water filter pump
    Hi,Last summer I bought a 12x12 Intex garden pool with a water filter pump. I somehow never had much confidence that the pump was doing very much and in fact, after a few weeks, the tubes turned green! I cleaned everything up and now I've set it up again for this summer. This time round I can see water flowing in the pipes... great. Except... the water flows nice and fast when the air valve is open (no water seeping out which I thought was odd) but when I close the air vent the water slows right down. Is the air vent supposed to be open or closed? My thinking is that faster flowing water = more efficient filtering? Thanks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Water filter pump
    Welcome Howitzerman!
    Are you talking about the vent on top of the little cartridge filter lid?
    There is only one reason those hoses turned green and that is due to a lack of free Chlorine in the water.
    Please begin reading in Pool School when you have a chance. The ABC's is a great place to start. Digest that as soon as you can, and work on other items from there. Knowledge and understanding are at the core of what we teach here. Once you learn, it's pretty easy.
    Essential Links:
    Jun 2014
    SWEDEN
    3
    Thanks for your reply. Yes, I'm talking about the vent on top of the cartridge filter lid. I'll read those ABC's but in the meantime should the vent be open or closed when running. I have it open when running at the moment as that seems to trigger a faster flow through the pipes. When I power off I close the vent to avoid the water leaking through the vent which it starts to do once I power off.
    Jun 2014
    SWEDEN
    3
    I suppose my point is this: From what I've read the air vent should be closed for running once you've vented any air. However I only seem to achieve any meaningful flow with the vent open!
    Jun 2013
    East TN
    309
    Sounds like when you open the so called vent the water is going elsewhere and not through the filter. Maybe you should check to make sure water is not bypassing the filter with it open.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
