Thread: Solar cover reel install
    Jun 2014
    Longueuil
    2
    Hi I just purchase this reel for my cover.
    http://www.poolsupplies.com/product/...-to-24-ft-wide
    I did all the install but need to put the straps on the cover. There is this plastics plates and screws and that go threw the perforated strap and but do I need puncture the cover?
    Thanks
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Solar cover reel install
    Yes you do according to the instructions. (See step 2)
    http://media.poolsupplies.com/docume...c68f2a8a33.pdf
    Jun 2014
    Longueuil
    2
    Quote Originally Posted by bobodaclown View Post
    Great thanks just wanted to make sure before putting holes in the solar cover.
    Should I take off the cover during the day even if no one is using it?
    Thanks
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Many people say that removing the solar cover during the day and just letting the sun hit it, will heat your pool faster, I use my solar cover of a night time, to help retain the heat it caught during the day...
    Welcome to TFP....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
