Thread: Aquarite no led's lit, but diagnostic display works.
    Jun 2014
    Atlanta Ga.
    4
    Post Aquarite no led's lit, but diagnostic display works.
    I am new to this forum, and need help. I have an Aqua Rite salt generator 5 years old. 18 x 36 inground pool. the t cell went out last week, I ordered a new one exact same cell that it came with it. T-cell 15, received it installed it yesterday, and it worked perfectly all day. Today I went out to check the salt reading and all of the led's are out. The display still works and the readings are :
    salt 3500
    temp 84
    volts 0.1
    currant 0.00
    output 84p
    salt -0
    al 2
    rl 1.40
    Checked the fuse, it's good. unplugged cell, plugged it back in, turned on and off several times. No flow light blinks for about 30 seconds, goes off, generating light comes on for a couple of seconds and goes off. Help please 90 degrees in Ga. will be green soon.
    Re: Aquarite no led's lit, but diagnostic display works.
    Welcome to TFP!
    This could just be a loose connection where the cell cable plugs into the control box, but it might also be the current limiter being burned out. If you are handy with soldering, it is possible to replace the current limiter yourself quite inexpensively.
    Jun 2014
    Atlanta Ga.
    4
    Is it normal for it to burn out at the same time the cell goes out? Is this the currant limiter, and is there a way to check it? Thanks Joe Digi-Key Part Number 570-1062-ND
