Thread: Stain on Vinyl pool
    Apr 2013
    61821
    8
    Stain on Vinyl pool
    http://farm3.staticflickr.com/2920/1...71495e07_b.jpg
    Opened ok so far except for the stain.The stain (picture) is around the entire sidewall right above the cove. Brushing does remove it some, I will be getting in the pool and begin scrubbing with brush and glove for scrubbing.using a Taylor K-2006 for the past 2 seasons. Thank-you
    FC: 10
    PH: 7.4
    TA: 140
    CH:110
    CYA: 40
    Doughboy 28 ft round 19k sandollar sd60
    Apr 2013
    61821
    8
    Re: Stain on Vinyl pool
    brushing helped but had to stop for the weather. question: would ascorbic acid help with the removal of this?
    Thanks
    There is no way to know if an AA treatment will help without testing. I kind of doubt it will help, since metal stains (what AA removes) never improve from brushing, still easy to check. Place a vitamin C tablet on a stained spot and see what happens. If the stain lifts in that spot, an AA treatment will help.
    Apr 2013
    61821
    8
    Thanks for info. I will try the crushed VIT C in a sock. The stain is from the top of the cove up about 12-14 inches. and stops.??
    Apr 2013
    61821
    8
    rubbing vitamin c did clean away the stain. I will go forward with the AA treament.
    http://www.troublefreepool.com/threa...f-metal-stains
