Thread: 1st test w/TF-100
    May 2014
    Mesa, Arizona
    180
    1st test w/TF-100
    I told Duraleigh that I would post results and here they are:
    FC=6.5
    CC=0.0
    TC=6.5
    TA=120
    PH=7.5
    CH=300
    CYA=80
    Salt=3000
    I suppose the only number I really have to address is TA and get my salt up to 3300-3400. Thoughts?
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: 1st test w/TF-100
    With a SWG and waterfall, your PH will always tend to rise. Keep that knocked down to the low end and that in turn will lower your TA.
    May 2014
    Mesa, Arizona
    180
    Should I put some MA in to knock down the PH and then turn on waterfall? We rarely use the waterfall as it's so loud.
    30,431
    Those are pretty good numbers. I would lower TA using the aeration/acid method in Pool School down to around 70 for an SWG pool. That may help your pH rise go a little slower.
    I think you are asking about using the waterfall to provide the aeration necessary to lower the TA by acid/aeration......that would be a perfect use. Read that lowering TA article carefully. It works fine but can be a bit confusing at first and it will take a little time.
    I think if the SWG was producing chlorine I might just leave the salt alone......either way is OK.
    With those good numbers, I assume you water is clear....correct?
    May 2014
    Mesa, Arizona
    180
    Pool Math has me using 59oz of MA to get to a target of 7.2 PH. I think I'll do that and then turn on the waterfall for a few hours and check later on.
    Yes, I've read the article a few times and have actually used the waterfall before to get the PH up a little after using acid when I was using the test strips before the TF-100 arrived.
    Water is crystal clear, have never seen it so clear since finding this site. Thanks again Dave for your prudence.
    May 2014
    Mesa, Arizona
    180
    FC-strong 5
    ph-7.1
    TA-80
    CYA-70
    Salt-3400
    SWG-70%
    Running aerator for a good portion of tonight into the day to push up PH. I think I'm done with fiddling around with the TA. I really don't want to go any lower. Going to dial in my SWG now as I've been trying out different setting %'s and had to boost it two days ago with some liquid chlorine as I had it turned down to 50% for a day and a half and lost some FC that day. Next few days I'm set on dialing that in and will report back with new solid workable reading that hopefully will be steady.
