Results 1 to 19 of 19
Thread: Just trying to take control before I lose it
    So we just finished the build. Been reading pool school and it has been a week and a half since getting keys. In that short week I think I have already lost control. Need to be able to show my husband we can do this before he calls a dreaded pool guy.
    Here is what my results look like
    FC .0025
    CC .0025
    pH. 8.0
    TA. 110
    cH 250
    CYA. 65
    I checked the canister on those pucks the PB has and it looks empty so it could definitely be that they are all gone and I want to move to liquid bleach.
    So if I am reading pool math right. I need
    50 oz of 12% bleach to raise my FC to 5. My question is should my goal really be 5 or 3?
    I also know my ph has to come down and will add the 14 oz of muriatic acid to lower to 7.5.
    I think the rest of my numbers are okay but just a little confused on where my targets need to be since the book that came with the Taylor test and the TFP site vary?
    Can you advise on if I have my thoughts right on the dosage and what my goals should be? Have my muriatic acid already going to run to store to get my bleach and will be ready to start. Thanks for your help
    In ground, 15x27, 80 feet perimeter, 3'6 to 5 feet deep, 9,600 gallons, 2 skimmers, 6 returns, Jandy VSP, Jandy DE 60, Jandy LXI, Nature 2 Ozone, 2 pool LED lights, 1 Spa LED light pebble tech aqua blue. Frisco,
    Texas
    In Ground 15X27 80 ft perimeter; 3'6 to 5' depth; 9600 gallons; 2 skimmers; 6 returns; Jandy VSP; 2 pool LED lights; 1 spa pool light; pebble tech aqua blue, North Texas build complete April 2014
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,467
    Re: Just trying to take control before I lose it
    I am guessing that you have a Taylor test kit. Is is the full test kit like in my siggy below?
    I would use the pool math and TFP goals. They tried and tested!
    Drop the pH to 7.4. After 30 minutes, raise the fc to 5.
    How did you get the fc and cc levels?
    Also, I would recommend not using ozone.
    Support the site
    Quote Originally Posted by kimkats View Post
    Yes I have Taylor test kit. Okay I will use the TFP goals
    Texas
    Quote Originally Posted by JamesW View Post
    I ran the FC and CC test out of my Taylor kit and got nothing that is why I believe my pool may have no chlorine. 😲😲
    I was too late fighting that battle with my PB. So it is part of my system. I guess I can work on figuring out how to turn off later? Do you think it will impact my results down the road?
    Texas
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,596
    Ozone has a tendency to consume a small % of your FC. Unplug that rascal!
    Oct 2013
    Chapin, SC
    1,141
    How much chlorine had you put in? Taylor has a lot of test kits, what's the model you have?
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Haven't put in yet. at store buying bleach now. PB had pool running off pucks
    Texas
    Note: The recommendation for a pH of 7.4 is only because your TA is a little high. I would recommend lowering the TA and raising the calcium hardness. Once the TA is down, I would keep the pH in the 7.7 to 7.8 range.
    The ozone will be counterproductive, in my opinion. It will destroy chlorine and it will oxidize metals. If you have floor returns, you will probably get metal stains around the returns. It should be easy to turn off.
    If you don't have an FAS-DPD test kit, it would be worthwhile to get one.
    Support the site
    Quote Originally Posted by woodyp View Post
    I will do. PB coming back this week to replace the iaqualink board for hubby so once I am done with him I will do that!!
    Texas
    Oct 2013
    Chapin, SC
    1,141
    My alkalinity coming out of the tap is 140-150 Don't worry about it till after or ever you get your fc where it needs to be. Do drop your pH though.
    James I realized my error in calculating my FC and CC. My FC should have been .5
    Texas
    Ok. Have you added anything yet?
    Support the site
    I added on Saturday 72 oz of 8.25% bleach and 14 oz of acid
    Texas
    We were gone Sunday so I tested again tonight and got
    FC 1
    CC 0
    TA. 110
    CH. 250
    CYA 58
    So tonight I added 20 oz of acid and 58 oz of bleach
    So I know I just got to keep getting that chlorine level up and my ph a bit further down.
    It has been 2 hours I wonder if I test again and dose the bleach again tonight?
    Texas
    So I tested again and am pleased with my results
    FC 8
    CC. .5
    PH. 7.4
    TA 100
    CH 250
    CYA. 50
    Texas
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    If you can't add chlorine to the pool regularly it's alright to occasionally overdose the FC a bit.
    For a CYA of 50:
    Minimum FC: 4
    Target FC: 8
    Shock level FC: 20
    You could shoot for halfway between target and shock which would be FC 14. That should buy you an extra day or 2 depending on sun exposure, and it's still safe to swim.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Quote Originally Posted by JesseWV View Post
    For a CYA of 50:
    Minimum FC: 4
    Target FC: 8
    Shock level FC: 20
    Thanks for the tip Jesse. My husband agreed to be the pool boy but he is slow coming around. I will get him there because I travel a lot for work so he is going to have to get on the TFP plan quickly!
    I feel like I am starting to have it all click in my brain.
    Texas
    Jul 2012
    Tallahassee, FL
    30,467
    Just write out a basic list of things for him to do.
    Mine has NO idea how to maintain the pool. His only job is to brush the sides. The one time he slipped on that I was able to show him the extra bill for bleach and he got to see the algae that was starting come off when I brushed the pool. He has been good at in since.
    When I had to go out of town for the weekend I just made a note for him to add __ cups of bleach to the pool each evening. I would call him to check in and ask if he did the pool yet. LOL It worked so..........
    Kim
