Results 1 to 9 of 9
Thread: Different versions of R-0871?
    kysoccer25's Avatar
    May 2014
    Shepherdsville, KY
    44
    Hey TFP folks! Here's the question. Through the process of cleaning my green monster, I am starting to run low on the R-0871 that came in my TF-100 kit. After doing a search online for a refill bottle, I noticed many different versions or abbreviations after the name. Is there a difference and if so, is it a big deal or unnoticeable?
    FAS-DPD Titration Reagent (Chlorine)
    • Site 1 - R-0871-E Taylor FAS-DPD Titration Reagent (Chlorine)
    • Site 2 - Taylor Technologies R-0871-C-12
    • Site 3 - TF Site lists it as R-0871
    • Site 4 - Taylor Technologies R-0871-A - FAS-DPD Titrating Reagent
    Thanks for your help!
    14.6k gallon pool (24'x52" round), AG Pool with sand filter
    Hayward Power Flo Matrix 1.5HP
    Pool and all equipment installed June 2011
    Thank you for your help!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Different versions of R-0871?
    Those are sizes and package quantity designations. It's easiest to get what you need from TFtestkits.
    It will be fresh and you'll get it faster than anywhere else.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    The alphabet suffixes are the size of the bottle. Chemically, they're the same.
    Results
    Reagent Number Reagent Description
    R-0871-A FAS-DPD Titrating Reagent (for chlorine), .75 oz, Dropper Bottle
    R-0871-A-24 FAS-DPD Titrating Reagent (for chlorine), .75 oz, Dropper Bottle, 24-pack
    R-0871-C FAS-DPD Titrating Reagent (for chlorine), 2 oz, Dropper Bottle
    R-0871-C-12 FAS-DPD Titrating Reagent (for chlorine), 2 oz, Dropper Bottle, 12-pack
    R-0871-E FAS-DPD Titrating Reagent (for chlorine), 16 oz
    R-0871-F FAS-DPD Titrating Reagent (for chlorine), 32 oz
    Reagent Size Code Explanation
    A = .75 oz (22 mL), A-24 = .75 oz (24 pack), A144 = .75 oz (144 pack), B = 2 oz (60 mL, wide-mouth),
    C = 2 oz (60 mL), C-12 = 2 oz (12 pack), D = 4 oz, DD = 8 oz, DB = dropper bottle, E = 16 oz, F = 32 oz,
    F4 = 32 oz (4 pack), G = gal, G4 = gal (4 pack), H = 25 g, I = 10 g, II = 50 g, J = .25 lb, K = 1 lb,
    Z = 1,000 pack, Z-10 = 10,000 pack, Z-50 = 50,000 pack
    kysoccer25's Avatar
    May 2014
    Shepherdsville, KY
    44
    Results
    How did you find that so quick?!? Thanks for the information.
    kysoccer25's Avatar
    May 2014
    Shepherdsville, KY
    44
    Quote Originally Posted by Brushpup View Post
    Hey there!
    I agree that it will be delivered faster than anywhere else BUT, here is the price difference which is key for me. I'm not going to list the site, only the price and qty. I bought my tf-100 and have recommended it to everyone else but I need to refill one item. If there is price matching, the TF store is a no-brainer!
    FAS-DPD Titration Reagent (Chlorine) 16oz = $19.49 / .75oz = $10.79 / 2oz = $14.99
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you want to get 16 oz then by all means do so. It will take a very long time to use that up and it may get too old before you do.
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    For those that may be lurking here, be aware that many places will list the -12 and -24 product numbers and only ship a single small bottle. This came up a couple of years ago when someone thought they had found an incredible deal at one of the major online sales sites.
    kysoccer25's Avatar
    May 2014
    Shepherdsville, KY
    44
    Under normal conditions, I would say that I would need just an average amount but as I am fighting a green monster and running a lot of tests, I need A LOT of the FC testing solution.
    Thanks everyone~
    Oct 2013
    Chapin, SC
    1,141
    unless you buy it from tftestkits or from Taylor Technologies, you have no idea how old or storage conditions it's been thru. I wouldn't trust it.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
