Thread: First time slam, strange results
    Feb 2014
    Sarasota
    43
    On friday i noticed a larger than usual chlorine drop. I decided to try the ofclt. Saturday morning I comeup with slightly over 1 ppm loss. By the way, pool water is crystal clear, no cloudiness when brushing. So I bring my fc level to 30 ppm. My cya is 65, I know a little overkill on fc. I maintain that level throughout the day and when the sun goes down, i bring the level up farther. 2 hours later I test to start the ofclt. This morning I test and get a loss of 12 ppm. How is it using more overnight now than before I slammed? I have the tf-100 test kit that I am using. Just trying to figure out what I have going on. Also, in 24 hours thr filter pressure has only increased 1 psi or less than 8%, which isnt any more than usual. I thought it would go up more since killing the organics?
    11,000 gallon gunite kidney pool. Krystal Krete blue pepper interior finish. Pentair Superflo VS pump, Pentair Clean and clear RP 100 filter. Goldline blue essence with T-15 SWG. Savi sol LED. 4 deckjets
    Re: First time slam, strange results
    Any chance something was in the pool overnight? Ducks? Raccoons?
    Or maybe the brushing uncovered some debris that is now sucking up chlorine.
    30,432
    well, the easy "fall back" answer is a testing error. You are correct that the results do not make sense so I would chalk it up to that and proceed.
    Your SWG is shut-off during the OCLT....correct?
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    SWG would mask a loss, not increase loss, wouldn't it?
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Feb 2014
    Sarasota
    43
    I had swg turned on during the day, turned it off 2 hours before the first step in ofclt. I did have a large frog in the skimmer. I guess what I am looking at, should I continue to slam and retry tonight or assume since my original fc loss test was so small that last nights was an error? The problem is, I am low on r-0871 reagent and no local pool store has it. So I will have to slam until Wednesday, due to shipping time. I know the true answer will be that I should continue to slam until I can retest the fc overnight loss. But are there any other indicators or tests I can do to refrain from slamming more than needed?
    Feb 2014
    Sarasota
    43
    Also will mention. Never had CC on any of the tests. Water temp ranges from 88 at night to 91 during the day. New pool in March. I took over balancing in April and chlorine has never been below 4 ppm on tests, even on the first ofcl
