Page 1 of 3 123 LastLast
Results 1 to 20 of 52
Thread: Help Me take my Pool back from the FROGS!!
    May 2014
    Loganville, GA
    23
    My pool has not been used for 1 year. My TF-1000 test kit came and I also got the extra r-0871 XL to go with it. All I did today is brush a little and removed some Algae. I really didn't see alot of leaves. More gooey, slimy yuck stuff..lol
    I really need a step by step of what to do first. I also have never done the BBB method. Do
    I need to give you guys the CYA results first? Since my pool looks like the Mother of Algae and breeding place for Frogs?
    18K gal, Vinyl, AG, Sand filter Hayward vari-flo XL valve, Hayward Power-flo LX pump HP 1.5, Polaris 6-130-00 Vac Sweep 65 AG pressure side pool cleaner, TF-100
    Jul 2012
    Herndon, VA
    419
    Re: Help Me take my Pool back from the FROGS!!
    post full test results!
    Adjust pH to 7.2
    SLAM!
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Bianca,
    Great job on getting that Test Kit with the XL option.
    I recommend to read how to SLAM before getting started. It will help you a lot!
    http://www.troublefreepool.com/content/119-how-to
    Next, please add some information about your pool and equipment to your signature. Here is how to do that.
    At the top of this page just under the Pool School Button, is 'settings'.
    Click Settings
    Scroll down that page, look on the left side, and you will see a "edit signature". Click that, and then add then add your pool and equipment info, similar to what I have done in my sig.
    It will help us to help you, if we know a bit about your pool. Also make sure to add in your sig which test kit you are using.
    Next, post a full set of test results - and we will go from there!
    Cant wait to see your sparkly clean pool!
    Divin Dave,
    Casey's Avatar
    SW PA
    10,444
    Ohhhhh.... look at that sanctuary!
    Please read ABC's of Pool Water Chemistry first!
    I won't post the next one because you are ahead of me and already bought the best test kit around! Good for you!!!
    I'll also recommend you post up the full set of test results and read Chlorine CYA Chart and SLAMing Your Pool coupled with PoolMath.
    You are soooooo gonna evict these frogs!!!
    Mar 2014
    south central PA
    112
    But they are soooo cute!
    28 ft round ABG with ~6ft deep end, approx. 20,000 gal, 2 spd 2 HP pump, sand filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    With as gunky as that water is you might want to strain it through a coffee filter before doing the CYA trubidity test
    May 2014
    Loganville, GA
    23
    Love the coffee filter idea! So, let me understand this correctly. Attach a coffee filter at the skimmer and just run the pool with no bleach?
    Ugh! Everytime my husband turns on the pump a pipe comes unattached. Last night we wanted to turn it on for the first time and pipe popped off. He sealed it around 8:00 pm and at midnight we turned it on and at another spot it came unattached so, we turned it off!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The coffee filter is for the test sample, the CYA test is a measure of how cloudy the water is after adding the reagent, if the water is already cloudy it can through off the test results. So straining a few ounces of water through a coffee filter can help with the accuracy of the CYA test
    May 2014
    Loganville, GA
    23
    Okay...thanks for explaining that...I will do that.
    May 2014
    Loganville, GA
    23
    FC 0
    PH 7.2
    TA 40
    CH 125
    CYA is below 20
    The pool has been looking like this all day due to the 2 bottles of bleach I put in yesterday and brushed. Pool has not been turned on as of yet.
    May 2014
    Loganville, GA
    23
    I did the tests on the white postcard that came with the test kit. What is the Fas/dpd test? It doesn't say on the postcard how to do this test?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    You did mix half pool water and half CYA reagent together before trying to get your CYA reading? If yes, then your CYa is less than 20.
    The FAS-DPD test is the powder, R-0870 amd R-0871.
    This youtube channel will show you how to run the tests http://www.youtube.com/user/TF100TestKit
    May 2014
    Loganville, GA
    23
    Yes, so my CYA is below 20
    This is my first time testing...my god I think it took me 30 minutes reading it word for word to make sure I didn't do anything wrong.
    So, do you guys need the results of the Fas-dpd also?
    I also just went ahead and bought the speedstir also I have it now...should I test the Fas-dpd with this or do it like the youtube video shows?
    Update...I just went ahead and did the Fas-dpd in the speedstir and the Result is 1
    What do I do now?
    Richard320's Avatar
    Jan 2010
    19,004
    Quote Originally Posted by Bianca View Post
    What do I do now?
    The pH is right on the money, so you start the SLAM. Just follow the directions.
    If I was there in person, I'd use poolmath to figure out how much bleach I need to get to 10 (That's SLAM level for <20 CYA) and add it. psst it's 2 full jugs of 8.25% clorox Then I'd weigh out enough CYA to get to about 25, just in case there's some left in there but too low to read. psst 4 lbs of stabilizer granules will do it. I'd put that in a sock or nylon and set it in the skimmer and start brushing and vacuuming. After an hour since the last bleach addition, I'd take another FC & CC reading with the FAS-DPD test and add enough bleach to get FC back up to 10 and finish my brushing and vacuuming. And if there's still time before bed, I'd test it and take it to 10 FC again.
    Tomorrow morning, I'd take a look at the filter pressure to be sure it wasn't loading up and needing a backwash and deal with that first if necessary Then I'd assume the CYA was dissolving and start using 12 as the FC target from then on out. And as often as I was able, I'd test FC and raise it back up to 12.
    I'd also take a picture to post so everyone can watch the progress.
    But that's just me.
    May 2014
    Loganville, GA
    23
    So, what is the stabilizer? Would that be the Borax or Baking Soda.
    Thanks for breaking it down that Pool Math had me confused at first, I guess I will all learn this the more I do it!
    Richard320's Avatar
    Jan 2010
    19,004
    Stabilizer is Cyanuric Acid. It might be called stabilizer or something else. Pool stores have it, so does Walmart, so do hardware stores that have a pool section. This article goes into more depth.
    Oct 2013
    Chapin, SC
    1,141
    Stabilizer's short name is CYA
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2014
    Loganville, GA
    23
    So, that would be in the pool section at walmart? Can I still add the 2 bottles of bleach now without the stabilizer? Or should I go buy it now if I want to add the bleach tonight? Its already 11:00 pm here.
    I don't know if I should do something tonight or wait for tomorrow?
    Apr 2014
    Hackettstown, NJ
    35
    go with the 2 bottles of bleach in the pool now, then out to the store for the stabilizer and a LOT more bleach. if you read through here, there are a lot of slam stories just like yours where folks go through 20-40 gallons of bleach.
    25.5K gal vinyl IGP 3.5' - 8' depth. 1.5HP single speed A.O. Smith C48L2N134B1 motor on a Hayward SP2610X15 Pump. 40 ft2 D.E. Filter Hayward model EC75A. Hayward Chlorinator model CL200. single skimmer, 2 Returns. TF100 Test Kit/Speed Stir.
  20. Back To Top    #20
    Walmart has stabilizer for about$12 and like DHoover said go ahead and pick up some regular Great Value bleach. My CYA was low like yours (which actually makes SLAming cheaper and easier) and it too me 16 jugs. However my pool looks great 2 years later and is easy to maintain. Good luck!
    27k gal, vinyl, Pentair SD-80 sand filter, Pentair 1.5 hp pump, intellichlor ic40 SWG
