Thread: sand filter and pump upgrade intex 16x32x52"
    May 2014
    mi
    27
    I have looked everywhere for this info and I am hoping you guys can help.
    I would like to upgrade my Intex 16x32x52" filter and pump.
    It came with a swg but I would like to change it to a Hayward pump and sand filter just not sure of the size or part number.
    If any one else has done this and can give some info
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: sand filter and pump upgrade intex 16x32x52"
    Hi there and welcome to TFP... Firstly what kind of connections for your suction and return do you have??? This will help with the decision of what pump to buy... Size of the connections would also be helpful....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    May 2014
    mi
    27
    The valves are Intex and the thread that I have heard is a strange thread, the size is 1.5 but I have no problem if I have to modify or cut something.
