Results 1 to 7 of 7
Thread: Return and Skimmer Placement
    May 2014
    Crowley,LA
    14
    When setting up an above ground pool. Do I want my returns or auctions closer to my pump. Or do I want them about equal. When placing returns and wall skimmers do I want the returns to face toward the skimmer and force water to the skimmer or be on the same side of the return like I've seen in most above ground pictures. Seems you would want the water force from the jets to propel trash toward the skimmer and suctions??
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Return and Skimmer Placement
    I've never set up an above ground pool, but I will tell you from hard experience that no amount of surface flow will overcome the wind. You want the skimmer downwind from the prevailing winds, otherwise all the leaves and bugs blow right on past the skimmer, get waterlogged, and sink for you to vacuum out later.
    30,426
    +1 What Richard320 said....it's the wind!
    May 2014
    Crowley,LA
    14
    So in the summer we mainly have winds from the Gulf (southerly) during the winter we have Northern wids a lot, but my pool should be covered at that point so I need my skimmers on the north side of my pool. So they catch the stuff the southern winds blow toward it. Correct?
    Richard320's Avatar
    Jan 2010
    19,037
    Yep.
    May 2014
    Crowley,LA
    14
    Thanks just to clarify you mainly elaborated on skimmer placement. So my returns need to be on the opposite side of the skimmer or does it really not matter?
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by RobbieBott View Post
    I don't know. Someone else with experience will have to answer that. I have multiple returns, but only one skimmer, so I know about poor skimmer replacement, but I can't comment on return placement.
