Thread: Possible to remove a blower from system?
    May 2014
    North Haven, CT
    4
    Quick background - We purchased a home, and it came with a "working spa" that turned out to have been left with water in it over winter. The damage wasn't outrageous, and I've replaced all the plumbing that needs it, but I've been reading a lot of negativity around blowers (no therapeutic benefit, major heat loss, not easy to winterize, etc). This system has a blower that pushes air out of 16 jet openings. I'd almost prefer to remove the blower and its jet network entirely, but I'm wondering how feasible that is. If they sold a part that screwed into the jet body but was sealed off, I could just get 16 of those, but that does not seem to be something that exists.
    Am I making more of this than it is? Does it make sense to just leave the blower alone and just use it once a week to keep the water in that network from stagnating?
    Thanks in advance.
    Re: Possible to remove a blower from system?
    Welcome to TFP!
    There is no harm in leaving the blower installed, just don't use it.
    Knoxville, TN
    41
    Most manufacturers install a check valve after the blower. There is no need to remove it unless you really want to.
    Hot Springs certified service tech A
    APSP CST Certified
    CPO Certified
