Thread: CH Test Results
    Jun 2013
    Austin, TX
    70
    CH Test Results
    Hi I'm curious which of these pics indicates the correct CH level. The first (more purple) photo is about 250, the dark blue is 300 and the last (bright blue) is 350. Normally, I had stopped when it was the 'dark blue', but recently I continued to add drops until it changed to the 'bright blue'.
    Thanks - John
    #1
    #2
    #3
    #4
    #5
    12k gal IGP/Spa, gunite, Jandy 2HP ePump VSP, Jandy CL 460 Cartridge Filter, LXI400 Heater, PebbleSheen, Polaris 280, stenner 45MPHP10 auto chorine feeder
    30,421
    Re: CH Test Results
    All drops based tests are completed when the last drop you add makes NO further color change. You then subtract that last drop from your total.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: CH Test Results
    You just keep adding until one of the drops has no effect on the color. With the CH test, massive amounts of mixing are required. Massive. When I switched from manual swirling to speedstir, I dropped about 200 ppm!
    So.. in your case, at 12, you're at dark blue. At 13, you're still at dark blue. At 14, it goes to light blue, the color you want to see. At 15, it stays light blue. No change at all. So the last drop did nothing. Subtract it. 15-1 is 14. Your CH is 350.
    Jun 2013
    Austin, TX
    70
    Re: CH Test Results
    Ok - thanks for the replies! BTW -I am using speedstir, I couldn't live without it!
