Thread: Hayward pool heater
    May 2014
    logandale nv
    2
    Angry Hayward pool heater
    Last week I got AO code which is vacuam control valve. While checking issue I got:bd code. Since I have changed ignitor control panel vacuam valve and fan motor. Stol have bd code that wont clear. What's up.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Hayward pool heater
    bd is a control board issue. You could try killing the power to the unit, flip circuit breaker, and then turn it back on and see if the error appears again. If error comes back, the control board is the likely culprit.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    May 2014
    logandale nv
    2
    That's board display on face. I've changed everything else and as you know parts are expensive. Have $500 in it already.
