Results 1 to 8 of 8
Thread: No way that coating is going to inhibit electrical passage
    Jun 2013
    Newcastle, Oklahoma
    508
    Split off of here. JasonLion
    Quote Originally Posted by Divin Dave View Post
    You need to use some sandpaper and remove that coating. The bonding lug should be full metal to metal contact with the posts. As it is now, only tiny area on the side of the screw through the post has you actually bonded, and thats not enough.
    no way that coating is going to inhibit electrical passage. if it did, we wouldnt have to bond in the first place. it will burn right through that paper thin coating like its not even there, in fact if if it didnt, electricity will arc, (jump) up to 2 inches. how do I know that? because the Taser X26 I carry every day on duty with 50,000 volts and 25 watts will arc through up to 2 inches of thick bulky clothing. And thats low voltage. High voltage will do more than that.
    I wouldnt take off the coating, that sounds like a sure fire way to promote premature rusting to me. electrician said it would be fine too, thats good enough for me.
    Quote Originally Posted by JasonLion View Post
    You are not normally supposed to have a ground rod.
    true, but it isnt gonna hurt either.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Re: No way that coating is going to inhibit electrical passage
    A layer of paint won't stop lightning, but it will stop 40 or 50 volts, and 40 to 50 volts is more than enough to kill you when you are in the water.
    An extra ground rod can indeed hurt. It creates a ground loop, which can unnecessarily cause ground currents to run through your bonding system, greatly accelerating the corrosion of the bonding wire.
    22,553
    Re: Bonding Question
    We're talking relatively low voltage here so your analogy of the taser isn't applicable here.
    While removing the coating would be best, it's probably not absolutely critical as the threading of the bolt will provide a path.
    Jun 2013
    Newcastle, Oklahoma
    508
    i donno. im not an electrician by trade. But the gentleman that is doing my electric has been for 30+ years and does pools all the time. He told me a ground rod is extra insurance. He also told me that coating is not an issue at all.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Quote Originally Posted by gtnos View Post
    no way that coating is going to inhibit electrical passage. if it did, we wouldnt have to bond in the first place. it will burn right through that paper thin coating like its not even there, in fact if if it didnt, electricity will arc, (jump) up to 2 inches. how do I know that? because the Taser X26 I carry every day on duty with 50,000 volts and 25 watts will arc through up to 2 inches of thick bulky clothing. And thats low voltage. High voltage will do more than that.50,000 volts is HIGH voltage. Low voltage electricity will NOT jump a two inch gap. I'll hold two wires with 110V potential a half inch apart and I'll guarantee they won't arc. You'd see lightning bolts jumping between the female terminals in every plug in the world otherwise.
    And I will add that from personal experience wrenching on cars for a living, a paper thin film of black lead-oxide corrosion on a battery post can stop a car from starting.
    Jun 2013
    Newcastle, Oklahoma
    508
    true....
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Electricians do very well with power circuits in the 100's of volts (110, 220). Those are very forgiving voltages for making connections. Electricians don't have to think much about joint reliability 'cause it's pretty much done for them with power voltage levels.
    Bonding is a totally different situation. Obtaining a long term reliable bonded connection requires cleaning the mating surfaces well. If you don't, it will appear to work fine at first, but will degrade much quicker than a well cleaned joint.
    I don't put any stock in what electricians say about bonding. It is totally outside their normal realm of expertise and many aren't able to demonstrate any level of competence by their bonding installations.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    You should consider hiring a new electrician.
    I know supposed 'pros' with 30 yrs expereince too, and I would hire them to mop the floor.
    Divin Dave,
