Results 1 to 13 of 13
Thread: Pool swg start up question
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    I had algae, so I drained my pool and now have refilled it and added salt. Its a 10' x 32"deep round intex above ground pool with metal frame. I know I have to add 32oz of stabilizer per pool math, but my question is do I add the stabilizer now, then run the pump for awhile and retest, or add stabilizer and turn swg system on then test. the intex manual is very vague about this.
    1200gal intex 10' x 30" round metal frame vinyl above ground pool, intex swg with 12"sand filter, tf-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Pool swg start up question
    You need to adjust the pH and get some bleach in there to hold things until the salt has 24 hours to mix. Then you can turn on the SWG. The stabilizer should go in a sock and either set it in the skimmer or hang it over the edge in front of a return. It will take a couple days to dissolve, so the SWG may not be able to keep up with the demand until the CYA level rises. Keep adding bleach to keep FC around 3 until the SWG takes over.
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    I have liquid stabilizer so do I let the salt mix for 24hr then put in the stabilizer?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    You can do both of those at the same time and circulate for 24 hours.
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    ok, I will add stabilizer with the salt, run for 24hrs, then test before I turn on swg......right? Or do I turn on the swg and let it run for 24hr then test the water? This is where I need advice....
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    Quote Originally Posted by mojopool View Post
    .....still waiting for an answer....please?
    Richard320's Avatar
    Jan 2010
    19,075
    If you're using liquid CYA, it will all be dissolved and dispersed in plenty of time. As long as the salt has had 24 hours to dissolve and mix, sure, fire off the SWG.
    You should test the FC every day anyway so you can adjust your SWG percentage properly.
    Add salt and stabilizer/CYA, run the pump for 24 hours with the SWG off, then turn on the SWG.
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    Thanks Richard, now another question, my swg is from intex it has the pump built in to it. The run time for the swg is the same for the pump. How do you figure how long you need to run the swg to keep up with generating chlorine? I had been running it for only 3hrs, should I be running the pump alone for more than that, or is 3hrs good for both?
    Thats what the chart says for my size pool and temperature.
    Richard320's Avatar
    Jan 2010
    19,075
    I have no clue. Never seen an intex SWG in the flesh.
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    intex.jpg here is a picture, the pump and swg system are all as one. the whole system can be programmed by hrs. you cannot run the pump seperatly unless you do it manually. I have another pump that came with the pool so I use that for additional pump time, just not sure how much I should be using the pump. I only have a chart for the whole system.
    Richard320's Avatar
    Jan 2010
    19,075
    All you can do is run it three hours or whatever and see what the FC level is. If it's not enough, run it longer. When it gets too high, turn it down a little.
    mojopool's Avatar
    May 2014
    TUCSON, AZ
    55
    Thanks Richard, I just wasnt sure if I needed to just run the pool pump alone for more time.....I will give it a try when I start it up tomorrow.
