Thread: Shocking my pool, do I adjust PH while shocking?UPdate jul14
    Mar 2007
    Ontario
    211
    Hello,
    I have brought my pool to shock level. My PH was 7.6 before I shocked.
    Now its off the charts. Do I adjust the PH now? Or wait till I am done shocking?
    Thanks
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Shocking my pool, do I adjust PH while shocking?
    Hi
    High schock levels can give false high ph readings. Don't do anything to your ph while shocking.
    Mar 2007
    Ontario
    211
    Thank-You for the quick relply
    Mar 2007
    San Rafael, CA USA
    12,082
    In the future if you know you are going to be shocking at high levels, above 20+ ppm FC for example, you can lower the pH in advance, say to 7.2. Otherwise, don't worry about it. The pH does rise when the chlorine is added and the FC gets high and then it drops back down as the chlorine gets used up.
    Mar 2007
    Ontario
    211
    Re: Shocking my pool, do I adjust PH while shocking?UPdate jul14
    I had a small algae bloom. My CL is now holding overnight within 1ppm.
    I have not had the solar cover on since the bloom.
    Is it save to put the cover back on? The cover looks clean but I worry
    about transfering algea from the cover. I have it drying out on chairs and
    a step ladder. thanks
    Mar 2007
    San Rafael, CA USA
    12,082
    If you want to play it safe, raise the FC to the higher end of the range you usually deal with before putting on the cover -- say an FC around 15% of the CYA level. Then check the pool each day to see how it's doing and if it is reasonably holding FC. I don't think you're going to have a problem, but this will help make sure you don't. If the chlorine is holding and the water remains clear, then you've killed all the algae and haven't introduced any more of any significance.
