Thread: Test Results For Newbie
    May 2014
    Salem, Oregon
    3
    We just put our above ground pool up and right off the bat I had green clear water. I shocked the pool, added metal chemical, stabilizer, etc. this morning my pool has a slight tint of green but very clear - here are my readings:
    CL - 4
    PH - 7.5
    TA - 140
    CH - 70
    CYA - 60
    What advice do you have for me?
    16x48 AG Intex Ultra Frame 6000 gallon Vinyl pool with a Krystal Clear Sand Pump 2150 gph.
    May 2014
    Salem, Oregon
    3
    Re: Test Results For Newbie
    FYI - sand filter not hooked up yet. We are waiting on our connectors so using the cartridge pump that came with pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Are you filling from a well?
    If yes, wait. Clear green water initially that gets way greener as soon as you hit it with bleach is metals in the water. It frequently goes away all by itself in a couple days. Use the search box for topics about well water and green with bleach and so on and you'll find you are not alone. If you've added sequestrant, give it time to work.
    Just maintain the pool chemistry as if the water was clear and untinted. If it hasn't gotten any better in another 24 hours, then more drastic steps will be needed.
    May 2014
    Salem, Oregon
    3
    We are on City water. The water color is better today than yesterday. I will wait it out. Thanks!
