Thread: Change speeds on a SuperFlo
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I saw this post when searching for how to install a switch to get two speeds. (Bama thats for that post very informative) I am looking to install a 1HP Pentair Super Flo and would like to so this instead of installing a new timer box. Can someone confirm that this will also work on a SuperFlo and possibly suggest a good location for the SPDT switch?
    I am a mechanical engineer but electricity is a second language so if someone knows of any additional posts covering this I would sure like to see it.
    Thanks everyone
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Re: Change speeds on a SuperFlo
    The two speed versions of the SuperFlo come with a switch on the motor housing. It is simplest to use that switch, though using an external switch is also fine.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Cool this is very good to know, thanks
    Polaris 280 robot
    Pool Calc user
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Quote Originally Posted by JasonLion View Post
    Jason looking at this SuperFlo dual speed pump it does not look like it has a switch. Am I looking at the pump you were referring to? I am a little confused. They do make a Super flow that has a control like a IntelleFlo but it is a variable flow.
    I need to pull the plug soon.
    Polaris 280 robot
    Pool Calc user
    They might have stopped including the switch, or the photos might be wrong. Difficult to be sure which is going on here.
    Even if there isn't a switch on the pump, it is very easy to wire up an external manual switch.
