Thread: Help w/ my used Intex Ultra Frame 16x48
    May 2014
    Tennessee
    1
    So I got the deal of the year on Craigslist a few months ago (or so I thought). I got an Intex Ultra Frame 16x48 pool w/ all the accessories and a SWG for $50. The only catch was the pool was filthy w/ clay mud and the seller made sure I knew it had a small tear in the liner. The accessories and pumps were stored away in plastic containers and seemed to be clean and working (we haven't gotten that far yet).
    So, we spent the last 3 weeks getting the ground ready for the pool. That is ready to go. Three days ago I got the pool out to clean and put it up. It took me 2 days to get it clean from all of the mud. I patched the tear and about four more holes yesterday with a vinyl patch kit. Today I got inside it and found about five more small holes and a tear. I also patched those. I crawled around the pool today and didn't seem to find any more holes but I am afraid I am missing something. Is there an easy way to look for more? Also I am terrified that the seams will leak. Does anyone know of some type of sealant I can use on the seams? Any help will be appreciated as we are 1st time pool owners.
    (FYI I knew their would be some work involved when I got $600 worth of pool equipment for $50, I just want to make sure I get it as leak free as possible because who wants to waste 5000 gallons of water LOL)
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: Help w/ my used Intex Ultra Frame 16x48
    I'm sure others will chime in when they get out of their pools tonight. I don't know about a seam sealant but as far as any small holes in the side walls, your patch kit should work underwater if you find any more leaks once you start filling.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    May 2014
    Washington State
    10
    I went through the same thing last summer. Bought an intex 14'x42" and patched several holes. The next day I patched several more holes, etc. By the end of it I had purchased another patch kit and still had multiple pin hole leaks showing up each day. You never know what type of care has been taken with a used pool, and this one had simply reached the end of it's life expectancy. I bought a new liner off of the intex website for $140 and consider it money well spent. I took the pool down for the year (I live in the NW where you can't leave an above ground pool up), and set it up again about a week ago. No problems, no leaks, easy pool. It's not a small cost, but cheaper than a new pool, and the replacement liner seems a bit thicker.
