Results 1 to 7 of 7
Thread: pool store chlorine vs. common laundry bleach
    Regular 'not fancy' laundry bleach has about 5% chlorine, the pool store guy says the chlorine level of the bleach he sells is around 13%.
    I have no way of knowing if this is true, but it does seem stronger. Is there a standard strength for pool store bleach?
    Is it worth the extra money over regular laundry bleach?
    6600 gal IG concrete/gemcoat
    Fresh water
    1 HP motor
    StayRite PLM 100 system 2 filter
    full sun
    Treasure coast, Florida
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,596
    Re: pool store chlorine vs. common laundry bleach
    Since last year, most bleach has now risen to 8.25% Just beware of anything that does NOT have that % listed on the label. Bleach is available up to 12.5% mostly from pool stores. Can also be called liquid shock.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If it's freshly manufactured, it does save bottles to lug around. Check the price per hypochlorite. $ cost/ounces/% hypochlorite. Compare that to store bleach. Also, higher % of hypochlorite will decay faster. So buy 12.5% stuff fresh and use it within a month or so if you go that route.
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,991
    Clorox and some store brands are 8.25% But they can drop dramatically. I saw some for sale once that was 1.75%.
    Pool chlorine is commonly 10% or 12.5%.
    If you crunch some numbers, you can figure out which way is cheaper per percentage/ounce. Here's just one of many threads discussing cost comparisons. Post 3 is probably the one you want.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    As others have said, be aware of old stock, particularly this time of year with Spring sales, that 12% may be left over from last year and really now no stronger than the fresh bleach on the shelves at the grocery store
    Thanks, my pool is fairly small so the savings would be neglible. I didn't know that Chlorine lost potency so quickly. Being from Florida where year round use of pools is common, I doubt that the pool store stocks are very old. I side with the convenience of using the "jug" from the pool store and trusting the readings of my Taylor test kit. Thanks for the input.
    Fresh water
    1 HP motor
    full sun
    Oct 2013
    Chapin, SC
    1,141
    The only place I'd trust for fresh bleach is a big box that gets bleach in two or three times a week. When I buy bleach it's at Wal-Mart where I know it's always fresh. I've seen the same stock of bleach at home depot that was there last year, and then it was 6 mos old!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
