Thread: How to replace Cell below water level
    So, my salt cell needs replacement after 7 years of use. I am trying to figure out the best way to replace it given that my equipment pad is below the water level of the pool.
    I am able to shut off the lines feeding the pump with a Jandy valve. However there is no such valve on the return side. The only thing I can think of is to plug all my returns in the pool. I have 3 returns plus a Polaris line. That wouldn't take too long, but I am wondering if there is even a better way to deal with this?
    Thanks!
    TF-100 Test kit, 24,000 gal. free form Vinyl. mybluepool AC-600 SWG, STA-RITE S7MD60 DE filter, 3/4 HP STA-RITE MPRA6D pump, Polaris 280 w/booster, Raypack Propane heater, Looplock mesh cover; All located in New England.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: How to replace Cell below water level
    Not any better way than what you already know. You're gonna have to plug those returns to change the cell.
    Divin Dave,
    Depending on the return, they can often be plugged temporarily with ping pong balls.
    I didn't have any ping pong balls, so I just ended up plugging the lines. Took all of 5 minutes. With the lines plugged and leaving the cover to the pump on, I must have created an air-lock. Lost about a pint of water is all
