Thread: CC test with Taylor K2006
    May 2014
    St Louis, MO
    37
    When testing, I do as per the directions and the water is clear(CC test). If I wait a couple minutes before I dispose of the water, it seems to have a pink tint to it. Is this normal? I'm assuming I am OK and that the test's are to be read immediately?
    24'x52" AGP 13,200 Gal Hayward Sand Filter w/ Matrix 2 speed pump Liquidator Taylor K-2006 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: CC test with Taylor K2006
    Your are correct. The FC test will also turn back to pink slightly if you let it sit. 😎
    Jeff
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    ^^^What he said...+1.
    It is also explained here (Post #4, third bullet point in the Notes section) --> Extended Test Kit Directions
    May 2014
    St Louis, MO
    37
    Thanks
