Results 1 to 14 of 14
Thread: Can you swim while adding CYA?
    May 2014
    St Louis, MO
    37
    Is it safe to swim while adding CYA?
    24'x52" AGP 13,200 Gal Hayward Sand Filter w/ Matrix 2 speed pump Liquidator Taylor K-2006 Test Kit
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Can you swim while adding CYA?
    Yes.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What Bo said ^^^^^ 😎
    Jeff
    May 2014
    St Louis, MO
    37
    thanks
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    pooley you can keep all your questions under one thread. It's easier for people to follow and see the history of what's going on. Just for future reference. 😎
    Jeff
    May 2014
    St Louis, MO
    37
    OK
    Should I have kept the FC at shock level during the entire testing period? Or just above the recommended max.?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If you had algae and were testing to see if your done with the SLAM, I would say to do an OCLT at SLAM level or close to it.
    To just do an OCLT to confirm there is nothing consuming chlorine you can do that at normal FC levels or slightly higher. 😎
    Jeff
    May 2014
    St Louis, MO
    37
    Just curious, loss of FC is to be 1ppm or less for OCLT. Then something other than daylight is consuming chlorine, correct? I guess it is minimal and safe?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Correct. If you lose more than 1ppm of FC over night then something other than sunlight is consuming it. You can still lose a little and be good on the OCLT.
    You are good to go. 😎
    Jeff
    PoolingAround's Avatar
    May 2016
    Katy, Texas
    213
    Bumping thread. Added a gallon of liquid cya in the morning. Safe to swim 6 hours later?
    Thanks.
    18k gallon, 20x32, salt IC20, gunite with quartz finish, raised spa with overflow, flagstone coping, moss rock waterfall, Pentair Intelliflo variable speed pump, Pentair Racer, Pentair pool pump, cartridge filter, heater, etc., acid dispenser.
    TF-100 kit for sparkling clean water.
    38,473
    Likely safe after 30 minutes
    May 2016
    Katy, Texas
    213
    Just want to make sure as I'm having people over today.
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    5,521
    Next time get the powder and save a bunch of money. Put it in a sock and hang in front of a return.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflo 3050VS Pump and Pentair HTR250 heater. IC40 SWG. EasyTouch 4. TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
    May 2016
    Katy, Texas
    213
    Sock too much hassle which I've done before. Somethings worth the money in my opinion.
