Results 1 to 12 of 12
Thread: Raypak 106 Won't Ignite
    bobhall98's Avatar
    Jul 2013
    Southwestern PA
    23
    I got a new Raypak 106, hooked it up tonight, first time I turned it on it sparked a few times and then it came on and seemed to working OK. Then it seemed to be turning off and on and finally it was off completely. I turned the switch off and back on but not hearing any spark, am I missing something?
    8200 Gal. AGP 12'x 24'x 54" Sharkline Oceanic - Hayward 1.5 Single Speed Pump - Hayward D.E. Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Raypak 106 Won't Ignite
    How's your filter pressure? Some heaters have a pressure/flow switch and if your flow is reduced it won't turn on.
    bobhall98's Avatar
    Jul 2013
    Southwestern PA
    23
    Pressure is good, just did back flush.
    bobhall98's Avatar
    Jul 2013
    Southwestern PA
    23
    It was the rollout switch, we jumpered it out and the heater started right up and worked perfectly. I was wondering if it is OK to run it without the rollout switch for a couple of days until I get a new switch.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Is this a brand new unit? You really need to figure out why the rollout went out. If this isn't a new unit then I would check to see if the heat exchanger needs cleaning. If you run the unit without the rollout and the flames do rollout it could burn up the wiring inside and then you have a bigger issue.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    bobhall98's Avatar
    Jul 2013
    Southwestern PA
    23
    Quote Originally Posted by ps0303 View Post
    It is a new unit, what would cause it to go bad? Do they go bad often? Could it have been bad from the factory?
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Anything is possible. I'd keep my eye on it though.
    Paul
    bobhall98's Avatar
    Jul 2013
    Southwestern PA
    23
    Raypak is sending me a new roll-out switch.
    Jun 2012
    western NY
    1,562
    I am going to guess maybe the air fuel mixture is not set right. Also, if it was going off and on prior to shutting down there may be something amiss with the exhaust. Maybe a pressure switch/blower fan problem.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    These units don't have blower motors.
    I would not know why it would have tripped the rollout but I would keep my eye on it. If it happens again, get a service person out to look at it.
    Paul
    Jun 2012
    western NY
    1,562
    Yeah, my bad. Probably should have spent some time looking that model up. We don't have anyone around here that sells Raypaks so I never really see one. Mostly Haywards
    bobhall98's Avatar
    Jul 2013
    Southwestern PA
    23
    Got the new roll-out switch, installed it, heater is working with no problems so far.
