Thread: Cloudy water
    May 2014
    Cottage grove, wi
    6
    Cloudy water
    I just opened up my intex for the third year and have been following the instructions for opening a seasonal pool. I have put 4 oz of pool shock plus by pool time that contains 58.2 % sodium dichloro s triazinetrione. I am on my 4th night and haven't really been swimming in it till today. All I have is a test that does chlorine and ph and I test at least twice a day. Right now the readings are at least 5 (goes to 5 and it's a deeper yellow then the last number) and my ph is 7.5. I run the filter 24/7 since it's the one that came with the pool
    Can u tell me if I just need patience and if it's ok to swim in. Thank you!!!!!!
    Intex round 12x12 easy set pool with the inflatable ring
    2100 gallons of water
    Crystal clear model 603 pump.
    38,475
    Re: Cloudy water
    Welcome to TFP!!!
    I did not think the seasonal pool article recommended the use of dichlor anymore? Can you provide a link for where you read that?
    Your pool is safe. Just watch the OTO chlorine test and add bleach as needed at this point.
    May 2014
    Cottage grove, wi
    6
    Re: Cloudy water
    I had printed and saved the article from at least last year and it worked so well that I didn't look any further. I have to admit it was hard to find. This is the explanation at the time. I thought u needed it for the cya.
    --Dichlor - chemical name is dichloro-s-triazinetrione, also called "pool shock". It frequently comes in small bags. Purchase approximately one pound for each 2,000 gallons, or fraction, of pool water. Dichlor adds both chlorine and CYA (stabilizer . . . "sunscreen" for chlorine). You will only use it for a few days, so don't buy more than what you need.
    38,475
    Re: Cloudy water
    Yes you need to add stabilizer. It is just simpler to add it and bleach separately than to try to balance the water using Dichlor.
