Thread: Solenoid Valves - Irrigation Timer for Swimmingpool
    May 2014
    Philadelphia
    3
    I Live in Thailand and are going to build a "public pool" there. Its gonna be about 70 X 35 feet.
    My question is: Is there any reason that i can't use Solenoid Valves and a Irrigation Timer for controlling my pool pump ?
    I vill have only one pump, but different "zones" and the pump vill probably run all day.
    38,251
    Re: Solenoid Valves - Irrigation Timer for Swimmingpool
    Welcome to TFP!!
    If you are in Thailand, why does your location say Philadelphia?
    I am not sure irrigation solenoid valves (at least the ones I have seen) have large enough pipe to support the flow rates typically needed in a pool application.
    May 2014
    Philadelphia
    3
    I am working in Philadelphia and living in Thailand. A few years ago i made my own pool in my garden, and last year i made a sprinkler system for my garden.
    I got the idea about using this valves and timer since its its so easy to operate in my garden.
    I vill use an 2inch valve whit flow rate of 150 gpm. The pump have a flow rate on 119 gpm.
    I asking about this since i thought the idea is good, but i can't find any information on this anywhere.
    My timer vill be controlled from a smartphone or computer and are very cheap.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I see one problem with it. On my sprinkler system, zone 1 shuts off before zone 2 starts and so on. You'd have to provide a path for the water coming out of the pump for those intervals when everything is closed.
    Why do you want zones? It's a neat idea, but I can't see why. Unless you're trying to make something like this
    May 2014
    Philadelphia
    3
    Yea now we talking not shore my pump could handle it.
    Its an fun idea.. i can control my pool from anywear in the world. I can have only one pump for the hole pool, but longer runtime. I can run the "jacuzzi" for 10 min, then the Shower/fountain 10 min....
    I vill have a start and stop relee for my pump and the pump vill run the hole time, but the valves is stacked. I vill have a 1/2 inch pipe open to bypass all the valves so it take of the pressure. I thinking of having one zone going bypass an chlorinfeeder as well. Then i can control the time of this zone to.
    (sorry for bad english, I'm from Norway)
    I know this thread is over a year old, but I'm interested in hearing if this concept worked...any follow-up information? Or anybody else tried this?
    14k gallon in-ground pool, Hayward Max-Flo II 3/4 hp pump & Hayward Perflex EC-50AC DE Filter
