Results 1 to 7 of 7
Thread: I Think I Finally Got It!
    May 2014
    NC
    2
    We got our round above ground pool last year and used Baquacil and this year we are using BBB. It has taken me a couple of weeks to get the hang of trying to get my readings correct. I have the Taylor K-2006 kit. I took a reading at 6pm and here are my results:
    FC - 6
    CC - 8
    PH - 7.2
    TA - 100
    CYA - 30
    If I am correct, I need to raise the PH and the CYA is borderline? Please advise. By the way, when I removed my cover to open my pool the water was just as crystal clear as it was when I closed it. SO far so good.
    Sandybele
    30" X 52" Round Above Ground Pool, Hayward Pump, sand filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: I Think I Finally Got It!
    Hi, welcome to TFP! If your CC is truly 8 then you need to complete the SLAM process. Did you do a Baquacil to chlorine conversion last pool season?
    You pH and CYA are fine for now.
    Love TFP? Become a
    TFP Supporter!
    38,271
    Welcome to TFP!!!
    Did you do the conversion from Baq to chlorine? It does not appear like you did based on the high CC levels (that should be zero).
    Review this: http://www.troublefreepool.com/threa...ol-to-chlorine
    May 2014
    NC
    2
    I did exactly what the pool store told me to do when I opened my pool. This is the first time I have gotten my FC up and the CC up like that. When I did the test for the cc some of the water spilled out prior to testing so maybe I need to retest my cc as it probably is not accurate. I will retest in the morning and see what the difference is.
    Sandybele
    38,271
    Forget what the pool store told you. You need to follow the process in the link I provided to remove all the Baq product in the pool. Then you need to replace the sand in your filter due to the gunk build up.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Think of CC as chlorine that got killed fighting algae. If you have no algae, there will not be any CC
    If you have algae, your CC will be high... Anything above .5 is considered high
    Divin Dave,
    Casey's Avatar
    SW PA
    10,428
    Did you do the whole conversion Sandybele? Those CC's are awfully high. Can you retest the water now so we can get a good jump on it tonight while the sun is going down?
