Thread: Hayward AquaPlus Aux1 Timer
    mpride's Avatar
    May 2008
    Sugar Land Texas
    73
    Well, with all the problems Iíve had with my Hayward AquaPlus controller I now have a problem I created. I was opening up the box to look at an onboard fuse I plan to replace with a lower amp circuit breaker (another issue) I accidentally touched the bottom of the board with a screwdriver. No I didnít shut off the breakers because I had not planned to really do anything except look. When I did this I shorted something momentarily. I didnít see or smell smoke and everything seemed to be functioning alright. However, Iíve found that my booster pump will not automatically turn on anymore. Itís connected to Aux1 and I can turn it on manually in service mode but the timer doesnít work anymore. The pump still turns on automatically though.
    Does anyone have any idea what I may have damaged on the board and/or how I might go about troubleshooting this problem? Any help or idea will be welcome!
    Mark
    IG Gunite * White Plaster * 26'9" x 14' * 310sqft * 70' Perimeter * 9300 Gallons * 2 Main Drains
    2 Skimmers * 4 Jets * Aqua Plus Control System * Aqua Rite Salt System * C3025 Cartridge Filter
    Tristar 2HP 2 Speed Pump * H400K Heater * Phantom w/Booster Pump * ColorLogic
    Re: Hayward AquaPlus Aux1 Timer
    Since it works in service mode, the relay is still good. That suggests to me that it might be a programming issue. Try double checking the schedule and make sure the booster pump is still scheduled to turn on.
    mpride's Avatar
    May 2008
    Sugar Land Texas
    73
    Quote Originally Posted by JasonLion View Post
    Thanks for the reply.
    I did check the timers and they are correct. Aux1 (booster pump) is scheduled to run at the same time the main pump runs on high speed. The main pump starts but the booster doesn't. I really don't know what to do with it. Is there anything else I might check.
    Mark
    mpride's Avatar
    May 2008
    Sugar Land Texas
    73
    Does anyone have any other ideas?
    I hate to think that I'll have to purchase a new board to replace this one to correct this problem. On the other hand, I can't imagine that I'm going to remember to manually turn the booster pump on each day either.
    Mark
    38,281
    Can you use Aux 2 instead? See if it works then?
