Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: New Guy Here!!!
    May 2014
    Claysville PA
    19
    New Guy Here!!!
    Just found this site and hope it can provide the info necessary to get a trouble free pool for years to come.
    Had the pool installed last year and everything was awesome. Closed it for the winter and apparently didnt winterize properly. no cover, pool still full of water. 2 weeks ago we started trying to get it ready for the season.....and we are still trying to get it ready for the season. It remains a terrible brown color at all times and visibility is no more than 10" from the surface.
    Hoping to find help getting it clear and keeping it clear all year with minimal work so i can spend more time enjoying it than tweaking it.
    21 ft - 10,407 Gallons, Above ground, Hayward CX1000RE cartridge filter, 1HP single speed pump 62gpm, installed May 12 2013
    Casey's Avatar
    SW PA
    10,453
    Re: New Guy Here!!! Timreams
    Welcome to TFP! You are in the right place! Please, check out Pool School. You will find a link to recommend test kits, the TF100 is the best value with more reagents. It makes pool care easy with reliable testing. You will also find educational material to help you understand easy pool care.
    May 2014
    Claysville PA
    19
    our local store uses a machine to test samples, is this an accurate test until we can get a kit? we were going to Pool City but they just test with the same little strips i can buy anywhere.
    Aug 2010
    Dallas, TX
    4,052
    The pool stores tend to be inaccurate due to the testing methods, the uninformed person performing the test, and lack of caring. This isn't true at ALL pool stores, but it is more common than not.
    May 2014
    Claysville PA
    19
    well apparently it doesnt matter. i was just told that we will not be buying a test kit of our own. we will just be getting a different filter and doing what we did last year. so once again everyone will get to enjoy the pool but me.
    so having said that what would be a proper setup for a 10.5k pool with a 62gpm pump?
    38,403
    Well, that is very close-minded
    Why do you need a new filter? That will not solve an algae problem if that is what you are thinking.
    A Recommended Test Kit is a small investment to make which will save a LOT of hassle and money in the future by avoiding pool stores and their magic potions.
    I just merged your other post into this one as it provides some info about your pool.
    You do not need a filter. You need to be able to test your chemistry and make informed adjustments.
    May 2014
    Claysville PA
    19
    Re: New Guy Here!!!
    thanks for the merge, i missed reading the notice about moderator approval when i posted the first time and couldnt figure out what went wrong lol.
    My wife believes we need a better filter to get the water clear again from the winter, once the water is clear i will just have to maintain it like i did last year, with chlorine, ph, up/down, stabilizer, algaecide
    Aug 2010
    Dallas, TX
    4,052
    Re: New Guy Here!!!
    Since you don't need a very expensive filter, get the actually reasonable TF-100 and tell the wife you saved her several hundred dollars.
    38,403
    Re: New Guy Here!!!
    This is 100% NOT a filter problem.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    With the right tool for the job, you will not need pH up/down, you will use cheaper muriatic acid. You will not need expensive algaecide (which may have copper and that can be a bigger problem) because you will be maintaining adequate FC.
    Not to start a fight, but if our methods are what you want to use (and you really should) and she wants to do something else ... wash your hands of the pool and make it her responsibility.
    I guarantee you can get a test kit AND clean the pool up for less than the cost of buying a new filter (and still have a brown/green pool).
    May 2014
    Claysville PA
    19
    Re: New Guy Here!!!
    I personally have read all of those links in Pool School and i do believe we can accomplish the task with minimal chemicals and the filter we already have.....this filtration system worked fine all last year. Granted we are in Pennsylvania so there is only really 3 months worth of swimming season before subtracting for rain days. LOL
    38,403
    Re: New Guy Here!!!
    Like a game of chicken ... how long will she be willing to look at an unmaintained and unusable pool if it is up to her
    Well, not sure what to say. I think you know the right path forward, up to you to decide if you are going to take it or be derailed.
    You could always let her buy the "new" filter and state that if it does not fix the problem (which it won't), she needs to step back and leave the pool decisions to you.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: New Guy Here!!!
    100% this. It's my first year using this site's knowledge and the wonderful people here and I know more about pools than every employee at the pool store, combined. After my experience, it's borderline insanity that I ever thought trying to let someone else manage the pool would be a good idea.
    Isolated Spa - 345 Gallons
    May 2014
    Claysville PA
    19
    Re: New Guy Here!!!
    yay, new guy wins. she is going to let me take a shot at fixing the pool with the same filter we already have.
    Feb 2014
    Central Minnesota
    5,080
    Re: New Guy Here!!!
    Quote Originally Posted by Timreams View Post
    And there was much rejoicing.
    38,403
    Re: New Guy Here!!!
    OK, so you are going to need the FAS-DPD chlorine test to do this correctly. If you can swing it, I would recommend the TF-100 with the XL option ... it should last you a few years stored properly. Ideally you would also get the SpeedStir, but not required. So get this ordered ASAP.
    Until then, I hesitantly suggest you get your water tested at a pool store. They are notoriously bad at testing, but better than nothing right now to get a feel for where you might be.
    Is there a gauge on your filter? Does it work? With a small cartridge filter it is going to be a pain to clear up the pool (frequent cleanings), but it is possible.
    Have you used a leaf rake to scoop out anything that might be on the bottom of the pool?
    You know you are going to need liquid chlorine and a lot of it, so start shopping for the best price. This calculator can help with that: http://www.troublefreepool.com/threa...ine-calculator
    And these would be a good review (maybe even have the wife look at them):
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    SLAM Process
    May 2014
    Claysville PA
    19
    Re: New Guy Here!!!
    i do have a gauge but it doesnt work. it quit working about a week after we installed the pool last year. the filter isnt really all that small. its a 100sq ft filter about 4ft tall.
    i have not yet used a leaf rake, we have just been using a standard pool vacuum.
    38,403
    Re: New Guy Here!!!
    You need to manually scoop out everything you can. And order a new gauge when you order the test kit. tftestkits has some nice liquid filled ones that cost the same as the junk ones you will find at a pool store.
    That filter is a decent size for your size pool, although larger would be better.
    May 2014
    Claysville PA
    19
    Re: New Guy Here!!!
    what would a good size filter be that will still work with a 62gpm 1hp pump? i have a 200# sand filter i could replace it with but it only says 2.53 sq ft so i am not sure how that is possible.
    38,403
    Re: New Guy Here!!!
    You can always use a larger filter, there is no minimum flow through them
    For a 10k pool, my general recommendations would be at least a 150 sqft cartridge or 2 sqft sand filter. But, you have a shorter season, so likely could get by with a little smaller.
    So, to me that sand filter is a better fit to your pool than the cartridge.
    A sand filter would be much less hassle initially with backwashing and clearing up the pool, but they can be a little slower later on to clear up the last bit of cloudiness (although some DE can help that).
  20. Back To Top    #20
    May 2014
    Claysville PA
    19
    Re: New Guy Here!!!
    can i use this until i get the better kit?
    http://www.shoppoolcity.com/products...quaChek-Select
