Results 1 to 7 of 7
Thread: Hayward Skimmer Installation Prior to setting up Pool
    May 2014
    Brentwood, CA
    76
    Hi folks, I got my Hayward skimmer and I am wondering if there is any way to install it on the pool liner while the pool is not set up yet. I haven't finished leveling the ground. I was thinking that if I can install it prior to pool setup, then I don't have to split the gasket into two therefore keeping the seal intact.
    Thanks.
    Intex 18' x 48" Ultra Frame Round Pool - AG, Intex Krystal Clear Model 28633EG 2500 Filter Pump, Intex Krystal Clear SWG #28663EG, TFT100 Test Kit, Hayward Skimmer
    duckcmmndr's Avatar
    May 2014
    Arkansas
    64
    Re: Hayward Skimmer Installation Prior to setting up Pool
    I don't think you would want to do it with no water in. I am sure as the weight of the water fills the pool....the liner "stretches" out somewhat and you would not want that stretching to take place after you cut a hole.
    My recommendation would be to fill the pool about halfway. That should be enough to stress the vinyl sides so that you can have a good flat surface to work with and without worries of anything changing after the hole is cut. If I had bought my skimmer prior to filling...this is the way I would have done it. I ended up installing mine with the pool full and had to split the gasket. No leaks and I really don't see any way it will ever leak. That vinyl is tough stuff. I installed the inner flange with half the gasket from the inside using an awl to poke holes in the side of the pool and push the screws through. With all the screws in place sticking out the outside of the pool there was hardly any leaks and half the screws were below the waterline. I was really surprised at just how tough the liner is.
    I am sure someone else will chime in...but that is how I would do it.
    Apr 2013
    Battle Creek, MI
    298
    Why not erect the pool and install the skimmer as it fills but before water reaches the skimmer level? You'll still be able to use the butterfly gasket as intended and you're likely for the side panel to be stretched more closely to its ultimate position. Trying to assemble the frame and liner with a clunky skimmer attached to it seems awkward.
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I just bought my skimmer for my rectangle intex this morning, and I was going to install it before I fill it too.... I did it for the suctions I replaced.... But I think what they're saying about the liner stretching for a larger hole like this is correct, so I've decided not to install it until its 3/4 full....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    May 2014
    Brentwood, CA
    76
    Thanks everyone for your advice. I really appreciate it. So, I will erect the pool and fill it up almost all the way to the skimmer level and then install the skimmer. I can't wait to finish my leveling. I have been doing it on and off for almost a week now after work and it is backbreaking especially working with clay.
    Thanks again everyone.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Levelling really sux, and yes its the necessary evil.... Really backbreaking work... Good luck...
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    Yes, I would fill to just below the skimmer before cutting. You want the liner to be fully stretched, and having it taut makes it easier to cut straight. Don't worry, it won't split. Here was mine:
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
