Thread: white flakes
    May 2014
    Chicago, IL
    12
    white flakes
    Ta150
    Ph under 7 I should have tested how much to bring it up to 7
    FC 4
    CC 0
    Cal 250
    Cya less than 30
    my pool was left untouched for 2-3 years I opened it went through the SLAM process. it now holds FC overnight and the water is pretty clear but I have a significant amount of white flakes in the water. I dropped the ph thinking the flakes were calcium deposits but no luck so far. there is also a gritty substance on the pool walls
    I have a sand filter
    Aug 2010
    Dallas, TX
    4,052
    Re: white flakes
    When TA and pH are off, you can get calcium scaling. I suggest getting that TA down to 70.
    Richard will probably chime in soon, he's the calcium expert.
    May 2014
    Chicago, IL
    12
    Re: white flakes
    I raise the ph to 7.2 but the ta is at 180.
    either it went up or I tested it wrong the first time.
    May 2014
    Chicago, IL
    12
    Re: white flakes
    also is it ok to swim with the ta this high?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: white flakes
    Quote Originally Posted by MattP22 View Post
    Sure. Lots of people have higher TA than that in the water they drink and bathe in.
