Thread: Draining for the new Liner
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    20 x 40 IN ground need to drain it for the new liner, is it ok to use the main drain and the pool pump to drain it?
    I was planning to set the spider valve to waste and just drain it in the back yard we have a pond that can handle the water.
    Bummed also, as I added borates last year now need new liner...
    20x40 Vinyl IG, 27k gal, 1 hp hayward, s244s hayward SF, Hayward SWG 1 floor drain, 2 Skimmers, 4 Returns, Fiberstars FO lights, Polaris booster, and 380 polaris cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Draining for the new Liner
    If you can isolate the main drain from the skimmer, absolutely. If you can't, as soon as the skimmer goes dry, you start sucking air and everything will stop.
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    Yes I can turn off the skimmers, and leave just the main drain open. My profile picture shows the valves.
    Would setting the spider valve to waste be the way to go?
    Richard320's Avatar
    Jan 2010
    19,046
    Yes. Then you're just pumping water straight from the pool out the waste pipe. The filter is taken out of the loop completely.
    DLaplante's Avatar
    Jun 2012
    Ham Lake, Minnesota
    31
    Very good thanks for the info. I'll be pulling that old liner out this weekend, then the real project starts.
