Thread: InteliChlor Salt Generator
    Jun 2013
    Auburn, AL
    16
    I currently have an IntelliChlor IC15 for my 15,000 gallon fiberglass pool. It is the original salt generator that was installed back in August of 2010. It is not producing chlorine anymore and I am needing to replace it. Would the IC20 work or should I stick with the IC15?
    Jonathan Smart
    17,000 Gallon, In Ground, Gunite, Sand Filter, VSP, Installed 4/2016,
    Re: InteliChlor Salt Generator
    Yes, the IC20 is compatible and will work fine. Personally, I would get an IC40, which will cost less in the long run, though it does cost more up front.
    May 2014
    Green Valley AZ
    2
    They only last for so many hours I put a timer on our pool and spa The pool is 56000 gal and use two IC 40s
    Jun 2013
    Auburn, AL
    16
    Thanks for your response!
    Jonathan Smart
