I just set up my 10 x 30 Intex Easy Set pool for the second year. Unfortunately, I stored the pump without a box and I think it is missing a gasket/o-ring.
It's there definitely supposed to be an o-ring under the top cover? I tried making one out of a piece of rubber from a bucket lid, but it is still leaking.
The o-rings on the hoses were completely degraded and ripped, but it seems like they don't really matter that much if I tighten the clamps all the way.
The top is a big problem though. The water leaks out unless the pump is higher than the pool, and then the pump won't pump. Help!
