Thread: cjwatkins
    May 2014
    augusta ga
    2
    cjwatkins
    HI I am trying out the BBB method for the first time.I do need to get a test kit though,where would you suggest i get my best deal? thanks for any and all advice
    7600 gallon intexpool
    sand filter
    ag pool
    1/5 hp game pump
    Jan 2013
    Houston, TX
    1,079
    Re: cjwatkins
    Welcome to TFP!
    Best test kit / best deal (and the one most of us use) is the TF-100. There is a link to it in my signature. If you have a green pool go for the XL option. If you like cool toys get the speed stir option. There is a comparison of the test kits we recommend if you do a search for recommended test kits.
    WHile you wait for your test kit - check out Pool School and the ABCs of Pool Chemistry.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Casey's Avatar
    SW PA
    10,424
    Re: cjwatkins
    Welcome. You can see the comparison Test Kit Comparison.
    You should also check out Pool School and read up on the many informational links put together to help aid you in caring for your pool.
